As I said I managed to access HA via ssh. This is what I got when typing
2022-08-27 19:11:51.655 ERROR (SyncWorker_2) [homeassistant.components.influxdb] Cannot connect to InfluxDB due to ‘HTTPConnectionPool(host=‘a0d7b954-influxdb’, port=8086): Max retries exceeded with url: /write?db=ggs (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x5f7b1da8>: Failed to establish a new connection: [Errno 111] Connection refused’))‘. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible. Retrying in 60 seconds.
2022-08-27 19:12:13.606 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error ‘ClientConnectorError’
2022-08-27 19:12:58.645 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error ‘ClientConnectorError’
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
2022-08-27 19:51:59.134 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-08-27 19:51:59.194 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-08-27 19:51:59.326 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration opensprinkler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-08-27 19:52:36.397 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2022-08-27 19:52:38.914 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=287 from 2022-08-27 16:09:36.161656)
2022-08-27 19:52:49.383 WARNING (MainThread) [homeassistant.setup] Setup of hassio is taking over 10 seconds.
2022-08-27 19:52:52.478 WARNING (MainThread) [homeassistant.setup] Setup of bluetooth is taking over 10 seconds.
2022-08-27 19:53:33.459 ERROR (SyncWorker_3) [homeassistant.components.influxdb] Cannot connect to InfluxDB due to ‘HTTPConnectionPool(host=‘a0d7b954-influxdb’, port=8086): Max retries exceeded with url: /write?db=ggs (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x6644c3b8>: Failed to establish a new connection: [Errno 111] Connection refused’))'. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible. Retrying in 60 seconds.
2022-08-27 19:53:35.628 WARNING (MainThread) [homeassistant.components.template.sensor] The ‘entity_id’ option near /config/configuration.yaml:232 is deprecated, please remove it from your configuration
2022-08-27 19:53:35.674 WARNING (MainThread) [homeassistant.components.template.sensor] The ‘entity_id’ option near /config/configuration.yaml:236 is deprecated, please remove it from your configuration
2022-08-27 19:53:35.691 WARNING (MainThread) [homeassistant.components.template.config] The entity definition format under template: differs from the platform configuration format. See Template - Home Assistant
2022-08-27 19:53:35.709 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform darksky is taking over 10 seconds.
2022-08-27 19:53:35.752 WARNING (MainThread) [homeassistant.setup] Setup of input_button is taking over 10 seconds.
2022-08-27 19:53:35.760 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2022-08-27 19:53:35.762 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2022-08-27 19:53:35.770 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2022-08-27 19:53:35.774 WARNING (MainThread) [homeassistant.setup] Setup of input_datetime is taking over 10 seconds.
2022-08-27 19:54:02.851 WARNING (MainThread) [homeassistant.components.mqtt] The ‘broker’ option near /config/configuration.yaml:51 is deprecated, please remove it from your configuration
2022-08-27 19:54:02.856 WARNING (MainThread) [homeassistant.components.mqtt] The ‘password’ option near /config/configuration.yaml:51 is deprecated, please remove it from your configuration
2022-08-27 19:54:02.862 WARNING (MainThread) [homeassistant.components.mqtt] The ‘username’ option near /config/configuration.yaml:51 is deprecated, please remove it from your configuration
2022-08-27 19:54:02.936 WARNING (MainThread) [homeassistant.components.binary_sensor] Setup of binary_sensor platform template is taking over 10 seconds.
2022-08-27 19:54:02.941 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform template is taking over 10 seconds.
2022-08-27 19:54:03.564 WARNING (MainThread) [homeassistant.components.mqtt] Deprecated configuration settings found in configuration.yaml. These settings from your configuration entry will override: {‘username’: ‘homeassistant’, ‘password’: ‘********’}
2022-08-27 19:54:04.765 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error ‘TimeoutError’
2022-08-27 19:54:04.795 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘Home’ for met integration not ready yet: Update failed: ; Retrying in background
2022-08-27 19:54:04.833 ERROR (MainThread) [homeassistant.components.input_boolean] Platform input_boolean does not generate unique IDs. ID water_tank_automation already exists - ignoring input_boolean.water_tank_automation
2022-08-27 19:54:14.262 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can’t connect to ESPHome API for irrigation-node @ 192.168.1.104: Error connecting to (‘192.168.1.104’, 6053): [Errno 113] Connect call failed (‘192.168.1.104’, 6053)
2022-08-27 19:54:14.449 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that uses str for device registry entry_type. This is deprecated and will stop working in Home Assistant 2022.3, it should be updated to use DeviceEntryType instead. Please report this issue.
Stack (most recent call last):
File “/usr/local/lib/python3.10/runpy.py”, line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File “/usr/local/lib/python3.10/runpy.py”, line 86, in _run_code
exec(code, run_globals)
File “/usr/src/homeassistant/homeassistant/main.py”, line 203, in
sys.exit(main())
File “/usr/src/homeassistant/homeassistant/main.py”, line 191, in main
exit_code = runner.run(runtime_conf)
File “/usr/src/homeassistant/homeassistant/runner.py”, line 119, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File “/usr/local/lib/python3.10/asyncio/base_events.py”, line 633, in run_until_complete
self.run_forever()
File “/usr/local/lib/python3.10/asyncio/base_events.py”, line 600, in run_forever
self._run_once()
File “/usr/local/lib/python3.10/asyncio/base_events.py”, line 1896, in _run_once
handle._run()
File “/usr/local/lib/python3.10/asyncio/events.py”, line 80, in _run
self._context.run(self._callback, *self._args)
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 538, in _async_add_entity
device = device_registry.async_get_or_create(**processed_dev_info) # type: ignore[arg-type]
File “/usr/src/homeassistant/homeassistant/helpers/device_registry.py”, line 371, in async_get_or_create
report( # type: ignore[unreachable]
File “/usr/src/homeassistant/homeassistant/helpers/frame.py”, line 74, in report
_LOGGER.warning(msg, stack_info=True)
2022-08-27 19:54:14.552 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template(“{% if states(‘sensor.water_tank_distance’)| float > 0 %} {% set range = states(‘sensor.water_tank_distance’) | float %} {% set full = 0.05 | float %} {% set empty = 1.05 | float %} {{ ((empty - range) / (empty - full) * 100) | round(1) }} {%else%} {{states(‘sensor.water_tank_distance’)}} {% endif %}”)
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 1679, in forgiving_float_filter
return float(value)
ValueError: could not convert string to float: ‘unavailable’
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 421, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 1906, in _render_with_context
return template.render(**kwargs)
File “/usr/local/lib/python3.10/site-packages/jinja2/environment.py”, line 1301, in render
self.environment.handle_exception()
File “/usr/local/lib/python3.10/site-packages/jinja2/environment.py”, line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File “”, line 1, in top-level template code
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 1682, in forgiving_float_filter
raise_no_default(“float”, value)
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 1395, in raise_no_default
raise ValueError(
ValueError: Template error: float got invalid input ‘unavailable’ when rendering template ‘{% if states(‘sensor.water_tank_distance’)| float > 0 %} {% set range = states(‘sensor.water_tank_distance’) | float %} {% set full = 0.05 | float %} {% set empty = 1.05 | float %} {{ ((empty - range) / (empty - full) * 100) | round(1) }} {%else%} {{states(‘sensor.water_tank_distance’)}} {% endif %}’ but no default was specified
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 537, in async_render_to_info
render_info._result = self.async_render(variables, strict=strict, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/template.py”, line 423, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ValueError: Template error: float got invalid input ‘unavailable’ when rendering template ‘{% if states(‘sensor.water_tank_distance’)| float > 0 %} {% set range = states(‘sensor.water_tank_distance’) | float %} {% set full = 0.05 | float %} {% set empty = 1.05 | float %} {{ ((empty - range) / (empty - full) * 100) | round(1) }} {%else%} {{states(‘sensor.water_tank_distance’)}} {% endif %}’ but no default was specified
2022-08-27 19:54:14.602 ERROR (MainThread) [homeassistant.helpers.template_entity] TemplateError(‘ValueError: Template error: float got invalid input ‘unavailable’ when rendering template ‘{% if states(‘sensor.water_tank_distance’)| float > 0 %} {% set range = states(‘sensor.water_tank_distance’) | float %} {% set full = 0.05 | float %} {% set empty = 1.05 | float %} {{ ((empty - range) / (empty - full) * 100) | round(1) }} {%else%} {{states(‘sensor.water_tank_distance’)}} {% endif %}’ but no default was specified’) while processing template ‘Template(“{% if states(‘sensor.water_tank_distance’)| float > 0 %} {% set range = states(‘sensor.water_tank_distance’) | float %} {% set full = 0.05 | float %} {% set empty = 1.05 | float %} {{ ((empty - range) / (empty - full) * 100) | round(1) }} {%else%} {{states(‘sensor.water_tank_distance’)}} {% endif %}”)’ for attribute ‘_attr_native_value’ in entity ‘sensor.tank_percentage’
2022-08-27 19:54:25.685 ERROR (MainThread) [homeassistant.components.homeassistant_alerts] Timeout fetching homeassistant_alerts data
2022-08-27 19:54:35.015 ERROR (MainThread) [custom_components.hacs] Makin-Things/platinum-weather-card - Repostitory structure for 0.0.3 is not compliant
