Tried to configure Dusck DNS, Here i was in the process.
Set up Duckdns Account
Copied token and configured Duckdns addon
Copied yaml file then started duckdns
checked configuration file and was valid so restarted.
Port forwarded in router to duckdns.org
after restart cannot access HASS.io on internal address OR on external address.
Pinged rapsberry pi and it responded so it is alive.
PLease any help you can provide. HAss.io is running on a Raspberry Pi 4.
Maybe. There are a number of issues that could prevent you accessing via the duckdns domain.
Try disconnecting a mobile device from your wifi and accessing the duckdns domain via the cellular network.
If that does work then the issue is that your router does not support hairpinning. You will have to use the IP address internally and the duckdns domain externally.
If it does not work then it could be a number of things.
