karansoi
(Karanbir)
October 28, 2019, 5:21am
1
I have a RPi4 with 4GB memory , a application class 2 SD card (64GB).
Formatted the SD card with GUIFormat and used the Balena etcher to flashed the image for RPi 4. Connected the board to my laptop running Windows 10. Waited for more than an hour. However cannot access Hassio using this
http://hassio.local:8123
Will appreciate help in this aspect.
francisp
(Francis)
October 28, 2019, 5:24am
2
Look in your router for the ip and try to access as xxx.xxx.xxx.xxx:8123
nickrout
(Nick Rout)
3
Maybe name resolution is not working. Try connecting via the IP address, eg http://192.168.1.23:8123
karansoi
(Karanbir)
October 28, 2019, 5:41am
4
Fancis and nickrout thanks.
This is what I did
In command prompt used ipconfig.( my laptop is connected to my google router on WiFi.
thet used this comand arp -a and this was the screen
From this i thought that my RPi4 IP address was 169.254.236.66
Now I used this address in my browser(Chrome) as
http://169.254.236.66:8123 , and this was the outcome
Let me know if i need to do something else.
karansoi:
169.254.236.66
That is an auto assigned dummy IP address a device gets when it can’t get one by static or DHCP… it’s not the IP address you are looking for.
None of your screenshots are visible.
nickrout
(Nick Rout)
October 28, 2019, 5:43am
6
Sorry neither of your screenshots come up on my screen. Beside the output of arp is not graphical so please copy and paste the code, not a picture.
nickrout
(Nick Rout)
October 28, 2019, 5:45am
7
Plus what @DavidFW1960 said, this is not the IP address you seek.
karansoi
(Karanbir)
October 28, 2019, 5:48am
8
C:\Users\Karanbir>ipconfig
Windows IP Configuration
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::48e9:f94c:44c5:ec42%13
Autoconfiguration IPv4 Address. . : 169.254.236.66
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
Wireless LAN adapter Local Area Connection* 10:
Media State . . . . . . . . . . . : Media disconnected
Wireless LAN adapter Local Area Connection* 1:
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : lan
Link-local IPv6 Address . . . . . : fe80::daa:aef0:e31:b0c2%4
IPv4 Address. . . . . . . . . . . : 192.168.86.21
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.86.1
Ethernet adapter Bluetooth Network Connection:
C:\Users\Karanbir>arp -a
Interface: 192.168.86.21 --- 0x4
Internet Address Physical Address Type
192.168.86.1 24-05-88-36-29-81 dynamic
192.168.86.255 ff-ff-ff-ff-ff-ff static
224.0.0.2 01-00-5e-00-00-02 static
224.0.0.22 01-00-5e-00-00-16 static
224.0.0.251 01-00-5e-00-00-fb static
224.0.0.252 01-00-5e-00-00-fc static
239.255.255.250 01-00-5e-7f-ff-fa static
255.255.255.255 ff-ff-ff-ff-ff-ff static
Interface: 169.254.236.66 --- 0xd
169.254.255.255 ff-ff-ff-ff-ff-ff static
C:\Users\Karanbir>
This page isn’t working169.254.236.66 didn’t send any data.
ERR_EMPTY_RESPONSE
This is the text
nickrout
(Nick Rout)
October 28, 2019, 5:49am
9
Is there a DHCP server in your network?
You need to check your router to see what IP address has been assigned to the RPi. It will be 192.168.86.x and shit that’s wireless so you must configure WLAN in Hassio via a USB stick.
francisp
(Francis)
October 28, 2019, 5:52am
11
You did put a network cable in your RBpi ? It looks like you try to access it from Windows. Linux does not have a c:\users.…>ipconfig
karansoi
(Karanbir)
12
I have a fibre optic connection on my opt data router, to this is connected my Google wifi router.
so DHCP is enabled for these.
karansoi
(Karanbir)
October 28, 2019, 5:54am
13
Yes the RPi4 is connected to my RJ45 on my laptop running windows 10.
nickrout
(Nick Rout)
14
Well how on earth does it connect with the DHCP server?
francisp
(Francis)
October 28, 2019, 5:55am
15
That will not work, unless you have some router software installed on your Windows, or ICS running.
francisp
(Francis)
October 28, 2019, 5:56am
17
You don’t have an ethernet hub, ethernet switch, ethernet router you can plug the RBpi in ?
You need to connect it to an ethernet port on your router
karansoi
(Karanbir)
October 28, 2019, 5:58am
19
Ok I will do this.
I need to wait for about half an hor for the update to complete?
What update? The Pi has no internet connection to update anything
