Cannot access Home Assistant externally (pfSense, HAProxy, ACME / total noob)
I am failing at correctly configuring external access for my Home Assistant on a recently acquired Green. I’ve followed the instructions in the video by Lawrence Systems but still cannot manage to connect, so any and all help is appreciated.
  1. I have bought my own domain and configured an A record (subdomain) to point to my IP. I think this is working because when I use dig (local, Google and Quad9) I get a response pointing to my IP.
$ dig @9.9.9.9 ha.mydomain.tld
; <<>> DiG 9.18.20 <<>> @9.9.9.9 ha.mydomain.tld
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 8523
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1232
;; QUESTION SECTION:
;ha.mydomain.tld.           IN      A
;; ANSWER SECTION:
ha.mydomain.tld.    1007    IN      A       200.x.y.z [yes, it matches my WAN IP on pfSense]
;; Query time: 3 msec
;; SERVER: 9.9.9.9#53(9.9.9.9) (UDP)
;; WHEN: Fri Dec 29 17:22:45 CST 2023
;; MSG SIZE  rcvd: 64
I can also ping my subdomain and get a response, from my computer or from the terminal in Home Assistant.
  1. The domain was bought via Namecheap and the ACME certificates configuration was done using their API and the cron entry has been enabled.
  1. I have tried both to listen on the WAN address and create a Virtual IP for HAProxy with the same results. In any case, firewall rules and NAT have been created for each situation.
  1. HAProxy has a frontend and a backend, but the server is always down and this message appears after each reload attempt:
[NOTICE]  : haproxy version is 2.8.2-61a0f57
[NOTICE]  : path to executable is /usr/local/sbin/haproxy
[WARNING] : config : Server HomeAssistant_ipvANY/HomeAssistant is DOWN, changed from server-state after a reload. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
  1. Configuration.yaml has been edited to include:
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 10.100.50.9 # HAProxy virtual IP
    - 10.100.50.1 # pfSense IP
I have run into both 503 errors and connection timeout errors, but I am beyond what I can solve here.
Thanks.
Is HA behind a proxy and firewall? If so, what is the role of pfSense and HAProxy? (Sorry, I can’t stand video tutorials.)
pfSense can be both firewall and proxy.
pfSense is my firewall, HAProxy is running within pfSense as a package on Netgate hardware.
I too prefer to read, but did not find a decent article.
Why not just install Wireguard on pfSense and have your own private VPN? It’s easy and it’s free and no third party providers are required, except for maybe dyndns if you don’t already have a static IP.
EDIT: Since you already have your own domain, dyndns would not be unnecessary. You have that already covered. Now just install Wireguard. Problem solved.
Ok, I see that HAProxy is a reverse proxy package for pfSense.
Can you already access the URL from the outside? I guess that’d be the HAProxy frontend. Based on the backend log looks like it can’t connect to HA.
Using the pfSense ping page, can you contact HA?
I know this would probably be more secure, but I do not know how to set up a VPN. Also, I do not think this resolves the reverse proxy situation where I could set up subdomains to specific services within my local network like Nextcloud or TrueNAS.
It’s pingable via the public IP, local IP and domain name.
EDIT:
I got rid of the virtual IP and the current status is a 503 error:
008 - browser blur
I assume this has to do with the backend being down, but I cannot get it to start.
Clearly Home Assistant is running and I can reach it via the local IP.
Yes, 503 means that HAProxy can’t contact HA.
How did you define the backend HomeAssistant? Also, check the pfSense logs for HAProxy entries.
After a couple of walkthroughs across the setup I realized the Home Assistant server was not available on port 443 so a tiny filament in my head lit up. I installed the Let’s Encrypt add on within Home Assistant and filled it with the Namecheap API details and it seems to work now:
I’ll try with my mobile device next.
Unfortunately mobile devices are unable to connect and reply with a 1001 error.
EDIT:
False positive, it is still only accessible locally.
What’s the error through HAProxy now?
No error, just a regular browser timeout. External ping is failing too. I can only access the URL if I am within the LAN/VLAN.
This is frustrating and not having the system accessible from the outside and mobile devices is pretty limiting. I am gonna go back to researching for a while.
Home Assistant should NOT have SSL enabled, and should remain on port 8123. The entire point of a reverse proxy is that it proxies the connection to the upstream server. HAProxy has SSL enabled already and you have a Lets Encrypt certificate. HAProxy is in charge of the SSL termination.
That is not the issue. Check the logs for Home Assistant, and see if there are many messages about not accepting the connection because it is not a trusted proxy.
For max security HA can and should have SSL enabled. That way the upstream link from the proxy to HA is secured as well.
I mean if it is in a production environment sure. But for home use I definitely would not recommend it. This forum is LITTERED with people who have set up SSL and for whatever reason something has gone wrong at some point after it was set up and now they are struggling to access their system. It’s always massively easier if port 8123 is still available internally, and served over plain http.
(The reason a lot of us went down this route incidentally, was because various bits of hardware, didn’t support speaking to Home Assistant over SSL - konnected.io being one of the main ones that was a problem)
Well, if someone already jumped into SSL offloading with a proxy, completing the secure link all the way to HA should be a minor step. But, yeah, for troubleshooting or initial testing better go step by step; always ensuring that at the end you have HTTPS all over. Even inside the LAN is a bad idea to be transmitting in plain text.
Ironically, I set up a Home Assistant Blue at my parents’ with a DuckDNS address and a Konnected alarm that is fully functional. I got a Green and a domain for my place and can’t even finish the setup :cry:
The only error in Home Assistant reads as follows:
Dec 30 22:59:58 homeassistant dockerd[590]: time="2023-12-30T22:59:58.250891146Z" level=error msg="[resolver] failed to query DNS server: 10.100.50.1:53, query: ;o427061.ingest.sentry.io.\tIN\t A" error="read udp 172.30.232.2:56985->10.100.50.1:53: read: connection refused"
The HAProxy logs may tell you what’s wrong with the upstream connection. Following the cue from andrew, you may try too to disable SSL on HA and see what HAProxy does.
That’s quite a worrying message to be fair, that says that Home Assistant was not able to resolve a DNS record via your router (10.100.50.1)
Guess what… That whole VLAN was not connecting to the local DNS. I have modified the rule that was causing the problem and it seems to be working now.
