Hi guys,
I have a raspberry pi running HA but I cannot seem to login into it.
I can ping it and also ping homeassistant.local (which gives the same ip address.
Not sure what could be wrong, used to work fine a few days ago.
Have the following error when I access HA Observer
It seems that your host is up but something is wrong with a docker or docker container. Try to reboot host. If it give you the same error you will have to ssh to it of hook up monitor to see what is going on.
