I’m fairly sure I’ve found a bug in how the state() function works in 2024.1.5/11.4
I’ve read this info (Last_updated State and last-changed in Lovelace) and this similar issue (difference between states and state_attr) as well as hours and hours of troubleshooting with chatGPT, but no luck.
Basically, I have a dozen 3d printers and I want to know if any of them stop drawing power (<20w), but only if they’ve been on for a while. The best way I’ve been able to figure this out is to use helpers and two separate automations - one to “start the clock” when they turn on (for at least 5s) and one to mark them as no longer printing (>5s). If they’ve been heating long enough when they turn off, they send an email, but getting the last_changed state from the helper is proving difficult.
I can retrieve it with:
{{ states.input_boolean.printer_01_printing.last_changed }}
but since I don’t want to set up 12+ automations, I have a formula to determine the helper based on the triggering entity I extract with another focmula, so I have to use:
{{ states('input_boolean.printer_' ~ printer_num ~ '_printing').last_changed }}
but this doesn’t seem to work. Even just plugging in:
{{ states('input_boolean.printer_01_printing').last_changed }}
Does not work (says “‘str object’ has no attribute ‘last_changed’”)
Would love help here, I’m at the end of my rope…
I know there are other possible ways to do this and I’m definitely open to it, but this also seems like a flaw that could/should be fixed if we can confirm I’m not just missing something…
