Hi all,
since one week I cannot access the Supervisor, File editor (to edit .yaml files), or terminal. I did not change anything, but the following errors appeared in my log:
Automations are working fine, and I can access the settings section.
Who can help me? Seems there is not much I can do without access to the configuration or terminal…
Detailed log as follows:
2020-08-04 20:55:03 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for shelly which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant. 2020-08-04 20:55:13 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for afvalbeheer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant. 2020-09-04 06:48:28 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:None [Connect call failed ('172.30.32.2', 80)] 2020-09-04 06:48:28 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version: 2020-09-04 07:43:29 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:None [Connect call failed ('172.30.32.2', 80)] 2020-09-04 07:43:29 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version: 2020-09-04 08:38:30 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:None [Connect call failed ('172.30.32.2', 80)] 2020-09-04 08:38:30 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version: 2020-09-04 09:33:31 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:None [Connect call failed ('172.30.32.2', 80)] 2020-09-04 09:33:31 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version: 2020-09-04 10:28:32 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:None [Connect call failed ('172.30.32.2', 80)] 2020-09-04 10:28:32 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version: 2020-09-04 11:23:33 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:None [Connect call failed ('172.30.32.2', 80)] 2020-09-04 11:23:33 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version: 2020-09-04 12:18:34 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:None [Connect call failed ('172.30.32.2', 80)] 2020-09-04 12:18:34 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version: 2020-09-04 13:13:35 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:None [Connect call failed ('172.30.32.2', 80)] 2020-09-04 13:13:35 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version: 2020-09-04 14:08:36 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:None [Connect call failed ('172.30.32.2', 80)] 2020-09-04 14:08:36 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version: 2020-09-04 15:03:37 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:None [Connect call failed ('172.30.32.2', 80)] 2020-09-04 15:03:37 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version: 2020-09-04 15:58:38 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:None [Connect call failed ('172.30.32.2', 80)] 2020-09-04 15:58:38 WARNING (MainThread) [homeassistant.components.hassio] Can't read last version: 2020-09-04 16:18:45 ERROR (MainThread) [homeassistant.components.hassio.http] Client error on api app/entrypoint.js request Cannot connect to host 172.30.32.2:80 ssl:None [Connect call failed ('172.30.32.2', 80)]
