Cannot access web gui after install on vmbox
So i have a bit of a nested virtualization situation running. Home Assistant is installed on a virtualbox inside a VM, it it set to use NAT as its network adapter. Installation went great and i see the welcome screen with an ip address to connect to
However trying to open access the webgui from http://10.0.2.15:8123/ or http://homeassistant.local:8123 both give the site cannot be reached errors.
Pinging the server from host also times out, but i can ping the host from my home assistant console
I have tried allowing tcp/8123 port as both inbound and outbound on my firewall but still can’t reach the webgui
If virtualbox is set to NAT, you have to forward port 8123 from your VM to VB
