I installed new HA and added a couple of switches. I am trying to setup Views and for some reason it does not show me anything that I am trying to see. Can someone help?
configuration.yaml:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Example configuration.yaml entry
homeassistant:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include sensor.yaml
The view option for groups doesn’t apply to Lovelace, which is the current default UI (and has been since version 0.86). You can take control of Lovelace and manually create views in the UI by going to Overview, clicking the three dots in the upper right, and clicking “Take control of Lovelace” (or something like that, it’s been a long time since I did that). Then click the dots again and click Configure UI and add whatever views and cards you want.
Not unless you go to Developer Tools > Info and click “Set states as the default page on this device.” Should probably move to Lovelace though since States has been deprecated for a long time and might go away at some point.
Thank you for your help, I know that I can create view with lovelace, I tried lovelace UI on one of my test HA installation. I just tried to understand why the groups.yaml file is still there during new installation.
