I know this isn’t really the right place to post this, but maybe someone else has solved this issue.
I’m trying to move my vacuum to Xiami so I can use it with Home Assistant.
When I add it manually, it will not be able to find it automatically. When I select the access point manually, it will go right back to the automatic search and act like I never added it manually.
I made sure my device is not disconnecting because it noticed no internet connection.
I’m going to assume this is a bug in the Mi Home software and needs a patch.
