Hi everybody,
I am trying to implement this advice I got.
However, suddenly I am not able to add any new entities. I have a /packages/<category>/
folder; the file /packages/heizungen/arbeitszimmer.yaml
did already exist, but I renamed it arbeitszimmer.yaml.deac
, which I always do do keep the file, but not have Home Assistant use it.
Now I re-created the file (without .deac
as file extension!!). It initially looked like this
input_boolean:
az_fenster:
I expected to find input_boolean.az_fenster
as a new entity after restarting Home Assistant. However, it was not there. I restarted the entire server, still nothing. I thought, perhaps something was wrong about the sensor. I added initial: off
, so the sensor would have a value. Restarted. Nothing.
So instead of figuring out what might have been wrong with input_boolean
, I tried to create a different entity:
counter:
az_fenster:
restore: true
step: 1
minimum: 0
maximum: 1
Upon restart, there was no counter.az_fenster
All my other integrations from these folders work fine! So I don’t understand why I cannot create new entities this way. I checked my configuration before each restart, and did not receive any errors. So there should not be anything wrong with the file… Yet nothing I create actually appears any longer.
What can I do? Thank you for your ideas
