I have a Mi Flora Plant sensor and I can read out all sensors data. I also created a plant element in my config. In the “Unused Entities” menu I see the element and it shows all sensors.
@Hackmett, I dont use hassio but in normal ha it will always start like that until you specify a plant entity as follows (in your case plant.daenerys):
I should have specified my question
How did you get that image there? The normal Plant Status Card doesn’t have an image parameter? Is this a custom card?
