Something happened to my Pi4 - it stopped working. Blinking green LED suggested “I2C Fault”. Also the SD card was wiped. Not sure what happened - I moved it from one room to another and had it on top of an electric water heater briefly while powered on. Dunno how that could have borked everything, but …?
Anyway, new SD, new Pi, same Zooz 800 ZST39R. Added the Z-wave / Z-wave-JS integration and it found all of my 7 GE Enbrighten switches. HOWEVER, they’re all in a sort of null state:
The only available action on any of them is Ping. Re-interview succeeds on all but one (which, after re-interview, it shows as Dead).
I reset all the switches (well, one won’t reset, perhaps that’s the “dead” one). I tried re-adding them, but it doesn’t find anything, just times out.
I have tried removing these devices. I have tried re-flashing the SD card.
Flailing, I tried updating the Zooz800 firmware (using the SiliconLabs tool) to 7.22 from 7.19.
More flailing, I got a whole new Zooz stick. This time it doesn’t gather those 7 switches (which are apparently stored on the stick?). But it won’t find any either. If I try adding via QR code, they don’t show up. It doesn’t prompt for a PIN. It just says they’ll be available once powered on (they are powered on). The added device just shows as “Provisioned”
So, this is just completely broken and I got nothing. This setup worked great for 2 years and now it’s just bricked. My next step would be to replace all the switches, but I have no confidence that things would work (and obvz no explanation as to why everything stopped working).
Any insights or help greatly appreciated, thanks.
