Cannot automate button with yeelight
Hello, i am trying to write my first automation and having some difficulties. I have a aqara button (round one) and I want to connect my yeelight to toggle on / off on click. I have following code (automations.yaml),
     - alias: 'Turn on bed room lights'
  platform: event
  event_type: click
  event_data:
  entity_id: binary_sensor.switch_158d0001e822ab
  click_type: single
- service: light.turn_on
  entity_id:
    - light.tv_light
But I get following error which doing check config. When I remove the above code from automations file then evenythink works fine.
Configuration invalid
Invalid config for [automation]: expected dict for dictionary value @ data[‘trigger’][0][‘event_data’]. Got None
extra keys not allowed @ data[‘data’]. Got None
extra keys not allowed @ data[‘trigger’][0][‘click_type’]. Got None
extra keys not allowed @ data[‘trigger’][0][‘entity_id’]. Got None. (See /config/configuration.yaml, line 110). Please check the docs at https://home-assistant.io/components/automation/
A good starting point would be to read the blue box on top of this topic and edit your post.
thanks i have changed that now
Formatting…
    platform: event
    event_type: click
    event_data:
      click_type: single
    entity_id: light.tv_light
Thank you very much sir, its working now.
I tried couple of hours in night but could not figure it out.
Is there any rules for indentation as I am using both atom and notepad++ but still same issues.
Regards
Basically:
  • always use spaces
  • indent sub-keys 2 spaces below their parent
The tough bit to get your head around is the second one, but you’ll get there eventually, here is an annotated copy of your automation that hopefully will help you visualise it…
- alias: 'Turn on bed room lights'    # sub-key of automation
  trigger:   # sub-key of automation
    platform: event   #sub-key of trigger
    event_type: click    #sub-key of trigger
    event_data:    #sub-key of trigger
      entity_id: binary_sensor.switch_158d0001e822ab    #sub-key of event-data
      click_type: single     #sub-key of event-data
  action:  #sub-key of automation
    service: light.turn_on    #sub-key of action
    entity_id: light.tv_light    #sub-key of action
if you are using a xiaomi button, does it actually work? there was a breaking change in something like 0.82
event_type: xiaomi_aqara.click
