Cannot build ESP8266 project elf2bin.py not found
I am trying to build my first project and have run into a problem.
/usr/bin/python3: can’t open file ‘/data/cache/platformio/packages/framework-arduinoespressif8266/tools/elf2bin.py’: [Errno 2] No such file or directory
This is ESPHome add-on on HAOS
Versions? Yaml? Full log?
ESPHome 2024.2.2
INFO ESPHome 2024.2.2
INFO Reading configuration /config/esphome/ph-sensor.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing phsensor (board: d1_mini; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 1.1.1
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- Wire @ 1.0
RAM:   [====      ]  40.7% (used 33316 bytes from 81920 bytes)
Flash: [====      ]  40.1% (used 418417 bytes from 1044464 bytes)
Building .pioenvs/phsensor/firmware.bin
/usr/bin/python3: can't open file '/data/cache/platformio/packages/framework-arduinoespressif8266/tools/elf2bin.py': [Errno 2] No such file or directory
*** [.pioenvs/phsensor/firmware.bin] Error 2
========================= [FAILED] Took 11.42 seconds =========================
esphome:
esp8266:
  board: d1_mini
wifi:
  ssid: ""
  password: ""
  ap:
    ssid: "pHSensor"
    password: "pHSensorPassword"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  # https://esphome.io/components/sensor/adc.html
  - platform: adc
    pin: A0
    update_interval: 1s
    unit_of_measurement: pH
    # https://esphome.io/components/sensor/index.html#sensor-filters
    filters:
      - median:
          window_size: 7
          send_every: 4
          send_first_at: 3
      # Measured voltage -> Actual pH (buffer solution)
      - calibrate_linear:
          - 0.59 -> 7.0
          - 0.71 -> 4.0
i2c:
  sda: D2
  scl: D1
  scan: true
display:
  - platform: lcd_pcf8574
    dimensions: 16x2
    lambda: |-
      it.printf(0, 0, "pH: %.2f", id(ph).state);
      if (id(ph).state < 4) {
        it.print(0, 1, "Very acidic");
      else if (id(ph).state >= 4 && id(ph).state < 5) {
        it.print(0, 1, "Acidic");
      else if (id(ph).state >= 5 && id(ph).state < 7) {
        it.print(0, 1, "Acidic-ish");
      else if (id(ph).state >= 7 && id(ph).state < 8) {
        it.print(0, 1, "Neutral");
      else if (id(ph).state >= 8 && id(ph).state < 10) {
        it.print(0, 1, "Alkaline-ish");
      else if (id(ph).state >= 10 && id(ph).state < 11) {
        it.print(0, 1, "Alkaline");
      else if (id(ph).state >= 11) {
        it.print(0, 1, "Very alkaline");
Guessing here but try a clean build
I am not sure, what you mean.
This was the result of my first build ever, or do you mean install the add-on?
Cleaned the build files and tried again.
Library Manager: Installing esphome/ESPAsyncTCP-esphome @ 2.0.0
INFO Installing esphome/ESPAsyncTCP-esphome @ 2.0.0
Unpacking  [####################################]  100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 3.1.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 3.1.0
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing ottowinter/ESPAsyncTCP-esphome
INFO Installing ottowinter/ESPAsyncTCP-esphome
Dependency Graph
|-- Wire @ 1.0
Compiling .pioenvs/phsensor/src/esphome/components/adc/adc_sensor.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/display/display.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/display/display_buffer.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/display/rect.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/esp8266/core.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/esp8266/gpio.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/esp8266/preferences.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/i2c/i2c.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/i2c/i2c_bus_arduino.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/i2c/i2c_bus_esp_idf.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/lcd_base/lcd_display.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/lcd_pcf8574/pcf8574_display.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/logger/logger.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/md5/md5.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/mdns/mdns_component.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/mdns/mdns_host.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/mdns/mdns_libretiny.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/network/util.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/ota/ota_backend_arduino_libretiny.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/ota/ota_backend_arduino_rp2040.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/ota/ota_component.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/sensor/automation.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/sensor/filter.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/sensor/sensor.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/socket/lwip_sockets_impl.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/socket/socket.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/wifi/wifi_component.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/wifi/wifi_component_libretiny.cpp.o
Compiling .pioenvs/phsensor/src/esphome/components/wifi/wifi_component_pico_w.cpp.o
Compiling .pioenvs/phsensor/src/esphome/core/application.cpp.o
Compiling .pioenvs/phsensor/src/esphome/core/color.cpp.o
Compiling .pioenvs/phsensor/src/esphome/core/component.cpp.o
Compiling .pioenvs/phsensor/src/esphome/core/component_iterator.cpp.o
Compiling .pioenvs/phsensor/src/esphome/core/controller.cpp.o
Compiling .pioenvs/phsensor/src/esphome/core/entity_base.cpp.o
Compiling .pioenvs/phsensor/src/esphome/core/helpers.cpp.o
Compiling .pioenvs/phsensor/src/esphome/core/log.cpp.o
Compiling .pioenvs/phsensor/src/esphome/core/ring_buffer.cpp.o
Compiling .pioenvs/phsensor/src/esphome/core/scheduler.cpp.o
Compiling .pioenvs/phsensor/src/esphome/core/string_ref.cpp.o
Compiling .pioenvs/phsensor/src/esphome/core/time.cpp.o
Compiling .pioenvs/phsensor/src/esphome/core/util.cpp.o
Compiling .pioenvs/phsensor/src/main.cpp.o
Generating LD script .pioenvs/phsensor/ld/local.eagle.app.v6.common.ld
Compiling .pioenvs/phsensor/libf70/ESPAsyncTCP-esphome/AsyncPrinter.cpp.o
Compiling .pioenvs/phsensor/libf70/ESPAsyncTCP-esphome/ESPAsyncTCP.cpp.o
Compiling .pioenvs/phsensor/libf70/ESPAsyncTCP-esphome/ESPAsyncTCPbuffer.cpp.o
Compiling .pioenvs/phsensor/libf70/ESPAsyncTCP-esphome/SyncClient.cpp.o
Compiling .pioenvs/phsensor/libf70/ESPAsyncTCP-esphome/tcp_axtls.c.o
Compiling .pioenvs/phsensor/libaf0/Hash/Hash.cpp.o
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/BearSSLHelpers.cpp.o
Archiving .pioenvs/phsensor/libf70/libESPAsyncTCP-esphome.a
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/CertStoreBearSSL.cpp.o
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/ESP8266WiFi.cpp.o
Archiving .pioenvs/phsensor/libaf0/libHash.a
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/ESP8266WiFiAP.cpp.o
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/ESP8266WiFiGratuitous.cpp.o
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/ESP8266WiFiMulti.cpp.o
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/ESP8266WiFiSTA-WPS.cpp.o
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/ESP8266WiFiSTA.cpp.o
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/ESP8266WiFiScan.cpp.o
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/WiFiClient.cpp.o
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/WiFiClientSecureBearSSL.cpp.o
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/WiFiServer.cpp.o
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/WiFiServerSecureBearSSL.cpp.o
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/WiFiUdp.cpp.o
Compiling .pioenvs/phsensor/lib67b/ESP8266WiFi/enable_wifi_at_boot_time.cpp.o
Compiling .pioenvs/phsensor/lib598/ESPAsyncWebServer-esphome/AsyncEventSource.cpp.o
Compiling .pioenvs/phsensor/lib598/ESPAsyncWebServer-esphome/AsyncWebSocket.cpp.o
Compiling .pioenvs/phsensor/lib598/ESPAsyncWebServer-esphome/WebAuthentication.cpp.o
Archiving .pioenvs/phsensor/lib67b/libESP8266WiFi.a
Compiling .pioenvs/phsensor/lib598/ESPAsyncWebServer-esphome/WebHandlers.cpp.o
Compiling .pioenvs/phsensor/lib598/ESPAsyncWebServer-esphome/WebRequest.cpp.o
Compiling .pioenvs/phsensor/lib598/ESPAsyncWebServer-esphome/WebResponses.cpp.o
Compiling .pioenvs/phsensor/lib598/ESPAsyncWebServer-esphome/WebServer.cpp.o
Compiling .pioenvs/phsensor/libecb/DNSServer/DNSServer.cpp.o
Archiving .pioenvs/phsensor/libecb/libDNSServer.a
Compiling .pioenvs/phsensor/lib3ff/ESP8266mDNS/ESP8266mDNS.cpp.o
Compiling .pioenvs/phsensor/lib3ff/ESP8266mDNS/LEAmDNS.cpp.o
Compiling .pioenvs/phsensor/lib3ff/ESP8266mDNS/LEAmDNS_Control.cpp.o
Archiving .pioenvs/phsensor/lib598/libESPAsyncWebServer-esphome.a
Compiling .pioenvs/phsensor/lib3ff/ESP8266mDNS/LEAmDNS_Helpers.cpp.o
Compiling .pioenvs/phsensor/lib3ff/ESP8266mDNS/LEAmDNS_Structs.cpp.o
Compiling .pioenvs/phsensor/lib3ff/ESP8266mDNS/LEAmDNS_Transfer.cpp.o
Compiling .pioenvs/phsensor/libb5a/Wire/Wire.cpp.o
Archiving .pioenvs/phsensor/libFrameworkArduinoVariant.a
Compiling .pioenvs/phsensor/FrameworkArduino/Crypto.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/Esp-frag.cpp.o
Archiving .pioenvs/phsensor/libb5a/libWire.a
Compiling .pioenvs/phsensor/FrameworkArduino/Esp-version.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/Esp.cpp.o
Archiving .pioenvs/phsensor/lib3ff/libESP8266mDNS.a
Compiling .pioenvs/phsensor/FrameworkArduino/FS.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/FSnoop.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/IPAddress.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/LwipDhcpServer-NonOS.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/LwipDhcpServer.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/LwipIntf.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/LwipIntfCB.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/MD5Builder.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/Print.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/Schedule.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/StackThunk.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/Stream.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/StreamSend.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/Tone.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/TypeConversion.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/Updater.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/WMath.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/WString.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/abi.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/aes_unwrap.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/base64.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/cbuf.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/cont.S.o
Compiling .pioenvs/phsensor/FrameworkArduino/cont_util.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_app_entry_noextra4k.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_eboot_command.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_features.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_flash_quirks.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_flash_utils.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_i2s.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_main.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_non32xfer.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_noniso.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_phy.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_postmortem.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_si2c.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_sigma_delta.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_spi_utils.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_timer.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_vm.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_waveform_phase.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_waveform_pwm.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_wiring.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_wiring_analog.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_wiring_digital.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_wiring_pulse.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_wiring_pwm.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/core_esp8266_wiring_shift.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/crc32.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/debug.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/exc-c-wrapper-handler.S.o
Compiling .pioenvs/phsensor/FrameworkArduino/exc-sethandler.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/flash_hal.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/gdb_hooks.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/heap.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/hwdt_app_entry.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/libb64/cdecode.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/libb64/cencode.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/libc_replacements.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/mmu_iram.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/reboot_uart_dwnld.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/spiffs/spiffs_cache.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/spiffs/spiffs_check.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/spiffs/spiffs_gc.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/spiffs/spiffs_hydrogen.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/spiffs/spiffs_nucleus.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/spiffs_api.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/sqrt32.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/stdlib_noniso.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/time.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/uart.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/umm_malloc/umm_info.c.o
Compiling .pioenvs/phsensor/FrameworkArduino/umm_malloc/umm_integrity.c.o
Compiling .pioenvs/phsensor/FrameworkArduino/umm_malloc/umm_local.c.o
Compiling .pioenvs/phsensor/FrameworkArduino/umm_malloc/umm_malloc.cpp.o
Compiling .pioenvs/phsensor/FrameworkArduino/umm_malloc/umm_poison.c.o
Archiving .pioenvs/phsensor/libFrameworkArduino.a
Linking .pioenvs/phsensor/firmware.elf
========================= [FAILED] Took 304.33 seconds =========================
I would try removing and reinstalling the addon then. You won’t lose your yaml files.
That did the trick, thank you
