I have setup Z-Wave on a Z-Stick 7 and added a couple of devices to HA. One is a Enlighten 3-way switch with the add-on which works perfectly. The other is a Yale YRD-210 deadbolt which was added without issue. I can lock/unlock it from the dashboard, but I cannot set or change any user pins. When I look at the users in Z-Wave JS they all show as disabled and if I try to enable them, it shows as enabled for a second and then goes to disabled again. The same if I try to set a pin, it shows as set for a second then it clears and it’s blank again. It also tells me to enable this id to be able to set schedules. How do I enable the users?
I did have 1 user code set at user 1 position from when I installed the lock, but it seems to have been wiped as I can no longer unlock it from the keypad with that code. I can still use the Master to unlock from keypad. Any help on how to get the user codes working would be appreciated.
