I recently was having trouble with my HA, so I decided to do a new clean install. I installed Raspian Jesse Lite just fine, and then input the download and install line for HA, but it always errors out at the same place (before I have to put in my password). Here is part of the log from my pip.log file:
Running setup.py install for cffi
Running command /usr/bin/python3 -c "import setuptools, tokenize;__file__='/tmp/pip-build-zd_up7e7/cffi/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-ait9vsax-record/install-record.txt --single-version-externally-managed --compile
File "<string>", line 1, in <module>
File "/usr/local/lib/python3.4/dist-packages/setuptools/__init__.py", line 12, in <module>
import setuptools.version
File "/usr/local/lib/python3.4/dist-packages/setuptools/version.py", line 1, in <module>
import pkg_resources
File "/usr/local/lib/python3.4/dist-packages/pkg_resources/__init__.py", line 70, in <module>
import packaging.version
ImportError: No module named 'packaging'
Complete output from command /usr/bin/python3 -c "import setuptools, tokenize;__file__='/tmp/pip-build-zd_up7e7/cffi/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-ait9vsax-record/install-record.txt --single-version-externally-managed --compile:
Cleaning up...
Command /usr/bin/python3 -c "import setuptools, tokenize;__file__='/tmp/pip-build-zd_up7e7/cffi/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-ait9vsax-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-zd_up7e7/cffi
Exception information:
File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 122, in main
status = self.run(options, args)
File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 295, in run
requirement_set.install(install_options, global_options, root=options.root_path)
File "/usr/lib/python3/dist-packages/pip/req.py", line 1436, in install
requirement.install(install_options, global_options, *args, **kwargs)
File "/usr/lib/python3/dist-packages/pip/req.py", line 707, in install
cwd=self.source_dir, filter_stdout=self._filter_install, show_stdout=False)
File "/usr/lib/python3/dist-packages/pip/util.py", line 716, in call_subprocess
% (command_desc, proc.returncode, cwd))
pip.exceptions.InstallationError: Command /usr/bin/python3 -c "import setuptools, tokenize;__file__='/tmp/pip-build-zd_up7e7/cffi/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-ait9vsax-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-zd_up7e7/cffi
