I’m using HA 0.57.2 on an Olimex Olinuxino A20 with Raspbian Stretch as OS.
I installed HA with pip in a virtualenv (like described on the HA Wiki).
For the zwave part, I use a usb stick Z-wave ZME UZB1.
The stick is seen in HA, when I try to pair securely, a new device is found but it always statys in "Sleeping(Probe) " state.
I tested various method (unpair/pair – factory reset – wiat all the night – test mode – heal network – restart network ) nothing works.
In test mode (from the Danfoss LC) the device wake up in HA and says “Vanne du salon changed to ManufacturerSpecific1” where “Vanne du salon” is the name that I gave to the device…and then goes in “Sleeping (Probe)” again.
It’s the only thing zwave in my home. I’m a bit lost with my first attempt at zwave things. I need help.
Here is an update of my findings.
Finally, HomeAssistant has nothing to do with the problem, nor openzwave.
The problem is DANFOSS !
I bought an LC13 and was confident that it would work out of the box…
but Danfoss does not want you to be free, so they made a new model that does not use the Z-wave standard but a proprietary version … that way, you cannot control it freely, you need to buy more Danfoss stuff that let them enter your home …
So, I stop my angry stuffs, the facts:
As stated here : https://homeautomationfordummies.wordpress.com/2015/01/01/danfoss-living-connect-lc-13-electronic-thermostatic-radiator-valves-z-wave-controlled/
there are three version of the same product and one of them does not use z-wave standards.
Here are the model numbers, for reference for other users. The model number is only found on the box of the LC13 ! Nowhere else.
014G0002 : Non standard z-wave … don’t buy that, it only works with other Danfoss products PROPRIETARY !
014G0012 : Z-wave OK
014G0013: Z-wave OK and optimized
So, I’ll try to get a updated from Danfoss … If it does not work, I’ll change and never by DANFOSS again
