Wesley2004
(Wesley Van Doren)
August 10, 2023, 1:28pm
1
I changed my router at home.
After this i cannot connect to HA with duckdns.
I port forwarded. It works with provider ip adres.
So port forwarded works.
I deleted duckdns. Added again.
Not working.
The ip address in duck dns is correct.
Who has idea??
reotto
(Rick Otto)
August 10, 2023, 1:36pm
2
Log-into DuckDNS and check the IP address it has?
Wesley2004
(Wesley Van Doren)
August 10, 2023, 1:50pm
3
You mean at duckdns website?
I did that and it’s still correct
reotto
(Rick Otto)
August 10, 2023, 1:51pm
4
Are you connecting internally or externally? Does either work OR they are both broken?
Wesley2004
(Wesley Van Doren)
August 10, 2023, 1:52pm
5
Internally works with ip and port.
External not working
reotto
(Rick Otto)
August 10, 2023, 1:54pm
6
What is your port forward? If you are using standard ports then you should be forwarding 443 to 8123.
Wesley2004
(Wesley Van Doren)
August 10, 2023, 1:55pm
7
I did 443 to 443 and 8123 to 8123?
reotto
(Rick Otto)
August 10, 2023, 1:58pm
8
Try port forward of 443 to 8123, and report the results.
Wesley2004
(Wesley Van Doren)
August 10, 2023, 2:04pm
9
Hero! That was the problem!
I thought it was another forwarding but it was wrong!
Tnx!
