Hi there, I’m new to Home Assistant so I’m sure this is user error. However, I can’t for the life of me figure out what I’ve done wrong.
I’ve set up HA on a Odoird-N2+ following this documentation. I’m using a Motorola Surfboard (circa 2013/2014) as my router with a Google Wifi Mesh System for the Wifi. My HA is plugged directly into the router via an ethernet cable as suggested in the doc.
I cannot connect to any device on my wifi network directly with an IP Address. In my troubleshooting, I’ve noticed that I also cannot ping the IP address of any smart device. Additionally my smart devices and HA seem to be on different subnets (Devices: 192.168.86.x; HA: 192.168.0.3).
Documentation suggests this shouldn’t be an issue, but since I can’t ping the devices, I suspect this is the problem. I’ve tried creating a local IP integration based on an issue I read in the forum (lost the link) and have also trie to create a ipv4 route based on this post, but once again no luck.
Full list of testing I’ve tried:
- HA UI set up for devices
- Manual YAML configuration
- Reinstall HA
- Set up bridge mode on Wifi/Router (not possible with a mesh, router doesn’t seem to have the ability)
- IP integration
- Set up ipv4 route
From here, I’m not sure what the next things to try are. Any advice or good search terms I could use would be greatly appreciated!
