I was hoping someone could help with hassio on a pi3 and duckdns , I have gone through the configuration of duckdns twice and I still cannot access my device outside of my home network - after I activate duckdns I can access my HA via the HTTPS://XXXX.duckdns.org:8123 on my wifi but the moment I turn off WiFi and try off network , ie via my cellphone I am not able to connect to HA or even display login. I have checked my wan IP and it is a match for duckdns up, I have given my my pi a static IP and I have tried with port forwarding to 443 to 8123 and I tried 8123 to 8123 (not aT same time though) both with same result, any suggestions out there?
is all you need. You may need to reset your router after turning on a port forward. And finnally, drop the 8123 when accessing the system. it should just be
Hi bosborne, yep followed these instructions, previously had to port forward to get some multiplayer games working
Anyone know what i can use to double check the ports are open? if the ports are not open what other options do I have? i assume it may be a ISP restriction?
Not sure what has changed in last 8 hours but I came home and tested it and it worked using 8123 to 8123, time to test the google assistant integration
That means it also works with 443 to 8123 w/o using the port. I’m guessing you were clearing the cache during each attempt, or you weren’t waiting long enough for the port forward to take effect.
I ended up changing it to 443 to test and it still works , but now I have a issue trying to get it to link up to Google assistant manually , another roadblock, had to post a separate topic for this
I had similar problem, i spent 3 days troubleshooting and it turns out that it was an ISP issue.
My isp has two ranges of IPs, one that allows remote access and one that doesnt.
I had to call them up and they told me: “just a sec, let us give you a different IP” and everything worked.
