I used the command below, I will remove the container and create a new one and modify command to include -p 8123:8123 to see if that gets things up and running back soon.
Command I installed with:
docker run -d --name="homeassistant" -v /boot/haconfig:/config -v /etc:/localtime:ro homeassistant/raspberrypi3-homeassistant
Command I will run and see what happens: docker run -d --name="homeassistant" -v /boot/haconfig:/config -v /etc:/localtime:ro -p 8123:8123 homeassistant/raspberrypi3-homeassistant
Edit: It works !!! wow so responsive better than Hassio !!
Is this the correct docker image for raspberry pis? The docker installation page only has a Linux section, which does not mention this. It uses homeassistant/home-assistant image.
I know the Linux version works fine on a VirtualBox linux vm.
I had just suggested to someone the other day that they try the docker install and they said it didn’t work. Looking at it, if they followed the instructions they probably got the wrong version.
But looking at your configuration, it looks a little odd
/boot seems a strange place to put you ha config files. Why have you put it there?
This doesn’t seem to match anything in the examples. Are you sure that works?
I want my HomeAssistant config files to be persistent on the boot volume of the sdcard so that I can samba from my windows machine. The folder is /boot/haconfig
on a Pi, the entire SDCard is persistent. /boot is a horrible place to keep files. just keep them in your /home/pi/ directory.
