Hi there,
I’m using hassio for a few months now and like it so far. However, yesterday there was a power outage. Since then homeassistant is not working anymore. I’m running homeassistant on a VM on my Synology.
First few times I could not load into the web interface. After a few reboots of the VM (and the Synology itself) I can access the interface. Only the lovelace dashboard loads partially. Not all cards load. The ones that load do work. All other pages say “Error while loading page X.”.
When I check the terminal via VM it says “cannot connect to the docker daemon at unix:///var/run/docker.sock. Is the docker deamon running?” and “Failed to write entry X”.
What am I doing wrong?
