Hello there!
I just restarted my RP4 with HA after what I thought was a pretty minor configuration change and I am now unable to connect to the web GUI, funnily enough I can SSH into it and i can see it in the connected devices in my network, I do have a few warning in my log, where should I look to identify what the issue is?
I have tried connecting to both hassio.local:8123 as well as https://192.168.0.xxx:8123/ with no luck.
If I SSH and run ‘hassio homeassistant logs’ I can see the following warning messages:
2019-12-30 17:11:33 WARNING (MainThread) [homeassistant.setup] Setup of person is taking over 10 seconds.
2019-12-30 17:11:34 WARNING (MainThread) [homeassistant.setup] Setup of group is taking over 10 seconds.
2019-12-30 17:11:34 WARNING (MainThread) [homeassistant.components.scene] Setup of platform homeassistant is taking over 10 seconds.
2019-12-30 17:11:34 WARNING (MainThread) [homeassistant.components.weather] Setup of platform met is taking over 10 seconds.
2019-12-30 17:11:34 WARNING (MainThread) [homeassistant.components.binary_sensor] Setup of platform updater is taking over 10 seconds.
2019-12-30 17:11:35 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.upnp
2019-12-30 17:11:35 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform mobile_app is taking over 10 seconds.
2019-12-30 17:11:35 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform tradfri is taking over 10 seconds.
2019-12-30 17:11:45 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform upnp is taking over 10 seconds.
If I run ‘hassio supervisor logs’ I notice the following warning message but not sure where to look to fix this:
19-12-30 17:21:00 INFO (MainThread) [hassio.api.security] /supervisor/logs access from core_ssh
19-12-30 17:21:15 WARNING (MainThread) [hassio.homeassistant] Don't wait anymore of Home Assistant startup!
Any help would be massively appreciated! I’d hate to have to start from scratch again!
learning how to make backups was on my list… I don’t currently have any…
