I cannot connect from HA to my Xiaomi Gateway at all. I have the latest Hass.io on RPI 3B+ (installed yesterday), the Hub has the latest FW installed. From MiHome app I can connect without any issues.
I tried almost everything I found on this forum to resolve this issue. However, without any success, the Hub does not communicate with HA.
This is how my log looks like:
2019-07-15 22:59:44 DEBUG (SyncWorker_6) [homeassistant.components.xiaomi_aqara] Expecting 1 gateways
2019-07-15 22:59:44 INFO (SyncWorker_6) [homeassistant.components.xiaomi_aqara] Discovering Xiaomi Gateways (Try 1)
2019-07-15 22:59:49 INFO (SyncWorker_6) [xiaomi_gateway] Gateway discovery finished in 5 seconds
2019-07-15 22:59:49 INFO (SyncWorker_6) [homeassistant.components.xiaomi_aqara] Discovering Xiaomi Gateways (Try 2)
2019-07-15 22:59:53 WARNING (MainThread) [homeassistant.setup] Setup of xiaomi_aqara is taking over 10 seconds.
2019-07-15 22:59:54 INFO (SyncWorker_6) [xiaomi_gateway] Gateway discovery finished in 5 seconds
2019-07-15 22:59:54 INFO (SyncWorker_6) [homeassistant.components.xiaomi_aqara] Discovering Xiaomi Gateways (Try 3)
2019-07-15 22:59:59 INFO (SyncWorker_6) [xiaomi_gateway] Gateway discovery finished in 5 seconds
2019-07-15 22:59:59 INFO (SyncWorker_6) [homeassistant.components.xiaomi_aqara] Discovering Xiaomi Gateways (Try 4)
2019-07-15 23:00:04 INFO (SyncWorker_6) [xiaomi_gateway] Gateway discovery finished in 5 seconds
2019-07-15 23:00:04 INFO (SyncWorker_6) [homeassistant.components.xiaomi_aqara] Discovering Xiaomi Gateways (Try 5)
2019-07-15 23:00:09 INFO (SyncWorker_6) [xiaomi_gateway] Gateway discovery finished in 5 seconds
2019-07-15 23:00:09 ERROR (SyncWorker_6) [homeassistant.components.xiaomi_aqara] No gateway discovered
2019-07-15 23:00:09 ERROR (MainThread) [homeassistant.setup] Setup failed for xiaomi_aqara: Component failed to initialize.
And sample config:
xiaomi_aqara:
discovery_retry: 5
gateways:
- key: yush2gk3e07gdme2
I tried lot of combinations of config values, empty mac causes a validation error for me.
I also tried nmap (from Windows):
Starting Nmap 7.70 ( https://nmap.org ) at 2019-07-15 23:32 Central Europe Daylight Time
Nmap scan report for 192.168.0.234
Host is up (0.082s latency).
PORT STATE SERVICE
4321/udp closed rwhois
9898/udp closed monkeycom
MAC Address: 78:11:DC:FB:2E:95 (Xiaomi Electronics,co.)
Nmap done: 1 IP address (1 host up) scanned in 24.66 seconds
So it appears the Hub cannot communicate on these ports. Again, tried to disable and re-enable wireless protocol in app for a few times.
Does this mean that this particular piece of Xiaomi Hub does not work with HA at all? I have read somewhere that some series, defined by MAC prefix, do not work. The only possibility there is to hack them by disassembling and soldering wires to UART and re-config it in a little ugly way. I hoped the Hub will work more or less out of the box.
