Hello everybody,
I am new to Home Assistant and I am tryng to set up a basic Home Assistant configuration with some Zigbee devices I already have. I am using Docker installation on a Ubuntu laptop (and I am new to Docker too).
I tested the ZHA integration (very easy to set up) but while I could easily connect to some LIDL and Sonoff devices, I could not finalise the configuration of some others (IKEA and Lexman).
So I moved to mqtt and zigbee2mqtt. I have got no error while configuring my containers. However, it looks like zigbee2mqtt cannot connect to mqtt broker; the last message the corresponding container log is:
Zigbee2MQTT:info 2022-05-09 21:19:47: Connecting to MQTT server at mqtt://192.168.xx.xxx
No other message follow and when I stop the container I get:
Zigbee2MQTT:error 2022-05-09 21:19:32: Failed to call 'Frontend' 'stop' (TypeError: Cannot read properties of null (reading 'clients')
at Controller.callExtensions (/app/lib/controller.ts:316:40)
at Frontend.stop (/app/lib/extension/frontend.ts:59:39)
at stop (/app/index.js:114:5)
at process.handleQuit (/app/index.js:120:9))
Zigbee2MQTT:error 2022-05-09 21:19:32: Not connected to MQTT server!
at Controller.stop (/app/lib/controller.ts:191:9)
I cannot figure out what’s going wrong. I have no log from mosquitto (even by adding log_type all
in its config file) to check from that side…however it looks like mqtt is running and correctly set up in Home Assistant (no error in that phase…but I do not know if there is any way to check that mqtt respond correctly to any request).
I add that the frontend of zigbee2mqtt is not available (which seems to confirm that zigbee2mqtt is not really ON even if I get no error message).
For information, I also add some errors previously with zigbee2mqtt (which crashed that time) because the USB zigbee dongle was still associated which ZHA. Since then, I removed the ZHA integration and that error went away…leading me to my actual issue: no error message, but zigbee2mqtt not really fonctional.
Thanks in advance for your help.
Here follows my docker-compose file:
version: '3.0'
services:
portainer:
container_name: portainer
image: portainer/portainer-ce
restart: always
ports:
- "9000:9000/tcp"
environment:
- TZ=Europe/Paris
volumes:
- /var/run/docker.sock:/var/run/docker.sock
- /mnt/soft_space/dockData/portainer:/data
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:stable"
volumes:
- /mnt/soft_space/dockData/homeassistant/config:/config
- /etc/localtime:/etc/localtime:ro
restart: unless-stopped
privileged: true
network_mode: host
mosquitto:
image: eclipse-mosquitto
container_name: mosquitto
volumes:
- /mnt/soft_space/dockData/mosquitto:/mosquitto
ports:
- 1883:1883
- 9001:9001
zigbee2mqtt:
container_name: zigbee2mqtt
image: koenkk/zigbee2mqtt
volumes:
- /mnt/soft_space/dockData/zigbee2mqtt/data:/app/data
- /run/udev:/run/udev:ro
ports:
- 8080:8080
environment:
- TZ=Europe/Paris
devices:
- /dev/ttyUSB0:/dev/ttyACM0
…and the config files of mosquitto :
persistence true
persistence_location /mosquitto/data/
log_dest file /mosquitto/log/mosquitto.log
log_type all
listener 1883
## Authentication ##
allow_anonymous false
password_file /mosquitto/config/password.txt
…and of zigbee2mqtt:
# Home Assistant integration (MQTT discovery)
homeassistant: true
# allow new devices to join
permit_join: true
frontend: true
# MQTT settings
mqtt:
# MQTT base topic for zigbee2mqtt MQTT messages
base_topic: zigbee2mqtt
# MQTT server URL
server: 'mqtt://192.168.xx.xxx'
# MQTT server authentication, uncomment if required:
user: hass
password: xxxxxxxxxxxxx
# Serial settings
serial:
# Location of CC2531 USB sniffer
port: /dev/ttyACM0
