Cannot controle Sonoff Touch from Hass.io
Can you post the page where you configura the %topic%?
OK cool let me go look through and see. Thanks
What settings have you got in user_config.h, in the tasmota software?
Everything in your original post looks fine, just to confirm you have given both devices different topics?
Sorry for the delay, yes the topic IS DIFFERENT on all the switches in the yaml .
mqtt:
broker: 192.168.0.224
port: 1883
client_id: home-assistant-1
keepalive: 60
username: Home
password: ride4fun
protocol: 3.1
birth_message:
topic: “tele/hass1/LWT”
payload: “Online”
qos: 1
retain: true
will_message:
payload: “Offline”
qos: 1
retain: true
switch:
  • platform: mqtt
    command_topic: cmnd/Garage/POWER
    payload_off: “OFF”
    payload_on: “ON”
    platform: mqtt
    qos: 1
    retain: true
    state_topic: stat/Garage/POWER
  • platform: mqtt
    command_topic: cmnd/Den/POWER
    payload_off: “OFF”
    payload_on: “ON”
    platform: mqtt
    qos: 1
    retain: true
    state_topic: stat/Den/POWER
  • platform: mqtt
    state_topic: “stat/kitchen1/POWER”
    command_topic: “cmnd/kitchen1/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    name: “Kitchen LED 2”
    state_topic: “stat/kitchen2/POWER”
    command_topic: “cmnd/kitchen2/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    command_topic: cmnd/DEN2/POWER
    payload_off: “OFF”
    payload_on: “ON”
    platform: mqtt
    qos: 1
    retain: true
    state_topic: stat/DEN2/POWER
  • platform: mqtt
    state_topic: “stat/kitchen3/POWER”
    command_topic: “cmnd/kitchen3/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    name: “Boys Room Main”
    state_topic: “stat/boysroom1/POWER”
    command_topic: “cmnd/boysroom1/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    name: “Boys Room Fan”
    state_topic: “stat/boysroom2/POWER”
    command_topic: “cmnd/boysroom2/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    state_topic: “stat/playroom1/POWER”
    command_topic: “cmnd/playroom1/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    name: “Master Bedroom Light”
    state_topic: “stat/masterroom/POWER”
    command_topic: “cmnd/masterroom/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    name: “Boys Bathroom”
    state_topic: “stat/bathroom1/POWER”
    command_topic: “cmnd/bathroom1/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    state_topic: “stat/backporch/POWER”
    command_topic: “cmnd/backporch/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    state_topic: “stat/hallway/POWER”
    command_topic: “cmnd/hallway/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    name: "Garage Light "
    state_topic: “stat/garage2/POWER”
    command_topic: “cmnd/garage2/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    name: “Front Porch Light”
    state_topic: “stat/frontporch/POWER”
    command_topic: “cmnd/frontporch/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    name: "Foyer Light "
    state_topic: “stat/foyer/POWER”
    command_topic: “cmnd/foyer/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    state_topic: “stat/playroom2/POWER”
    command_topic: “cmnd/playroom2/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    state_topic: “stat/switch1/POWER”
    command_topic: “cmnd/switch1/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    state_topic: “stat/outdoor1/POWER”
    command_topic: “cmnd/outdoor1/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    state_topic: “stat/outdoor2/POWER”
    command_topic: “cmnd/outdoor2/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
  • platform: mqtt
    state_topic: “stat/outdoor3/POWER”
    command_topic: “cmnd/outdoor3/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
Couple of things, can you show what the payloads are for the switch in the tasmota sw please.
Also the LWT message should be set in the tasmota sw for each device as its the LWT for the device that you’re interested in not the broker, tho’ that is important :wink:
I’m sorry I dont understand what LWT is.
Last Will and Testament allows the device to notify HA/you that it’s gone offline, basically the device subscribes to the broker with a LWT message such that when it goes offline the broker knows and can notify HA it has gone down :slight_smile:
makes sense, so how should it look?
You would need to create this for each device… (in your switches.yaml)
availability_topic: “stat/outdoor3/LWT” <----- topic would need to be changed for each device.
You may also have to change the tasmota sw too, but I think it will work like this, again I know next to nothing about tasmota so maybe someone else knows more :wink:
I tried changing this in .yaml but like you said it might have to be changed on the switch side SW also… : its going to suck having to pull all of these out of the wall…
I wouldn’t worry about it to much, you can always do it as and when :slight_smile: , tho’ I thought you could do OTA with tasmota?
you might can but I’ll have to figure that out too…
If you are using the Arduino IDE, when you go to the programming tab then in the com ports menu there should be all your currently online devices, you then select the one you want :), if you can’t do that then there is usually a web page for the device and you can do it from there I think.
I used the program ATOM to flash all the sonoff. I didnt use IDE. I can access the webpage but its looking for a firmware.bin file im assuming i have to create that?
I think you will find that ATOM is just the editor, platform IO is the IDE :slight_smile: When you compile the code that .bin file should be made by the IDE, where it puts it, I have no idea :stuck_out_tongue:
OK that helps… let me dig around see what i can find.
Can I change what I need on this page from the sonoff?
Here is the Userconfig.h file from the Tasmota you requested.
user_config.h - user specific configuration for Sonoff-Tasmota
Copyright © 2017 Theo Arends
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see http://www.gnu.org/licenses/.
#ifndef USER_CONFIG_H
#define USER_CONFIG_H
  • ATTENTION: Changes to most PARAMETER defines will only override flash settings if you change
  •        define CFG_HOLDER.
  •        Most parameters can be changed online using commands via MQTT, WebConsole or serial
  • Corresponding MQTT/Serial/Console commands in [brackets]
// – Localization --------------------------------
//#define MY_LANGUAGE en-GB // English in Great Britain. Enabled by Default
//#define MY_LANGUAGE nl-NL // Dutch in the Netherlands
//#define MY_LANGUAGE de-DE // German in Germany
//#define MY_LANGUAGE pl-PL // Polish in Poland
// – Project -------------------------------------
#define PROJECT “sonoff” // PROJECT is used as the default topic delimiter and OTA file name
// As an IDE restriction it needs to be the same as the main .ino file
#define CFG_HOLDER 0x20161209 // [Reset 1] Change this value to load following default configuration parameters
#define SAVE_DATA 1 // [SaveData] Save changed parameters to Flash (0 = disable, 1 - 3600 seconds)
#define SAVE_STATE 1 // [SetOption0] Save changed power state to Flash (0 = disable, 1 = enable)
// – Wifi ----------------------------------------
#define WIFI_IP_ADDRESS “0.0.0.0” // [IpAddress1] Set to 0.0.0.0 for using DHCP or IP address
#define WIFI_GATEWAY “192.168.2.254” // [IpAddress2] If not using DHCP set Gateway IP address
#define WIFI_SUBNETMASK “255.255.255.0” // [IpAddress3] If not using DHCP set Network mask
#define WIFI_DNS “192.168.2.27” // [IpAddress4] If not using DHCP set DNS IP address (might be equal to WIFI_GATEWAY)
#define STA_SSID1 “" // [Ssid1] Wifi SSID
#define STA_PASS1 "
*” // [Password1] Wifi password
#define STA_SSID2 “indebuurt2” // [Ssid2] Optional alternate AP Wifi SSID
#define STA_PASS2 “VnsqrtnrsddbrN” // [Password2] Optional alternate AP Wifi password
#define WIFI_CONFIG_TOOL WIFI_WPSCONFIG // [WifiConfig] Default tool if wifi fails to connect
// (WIFI_RESTART, WIFI_SMARTCONFIG, WIFI_MANAGER, WIFI_WPSCONFIG, WIFI_RETRY, WIFI_WAIT)
// – Syslog --------------------------------------
#define SYS_LOG_HOST “domus1” // [LogHost] (Linux) syslog host
#define SYS_LOG_PORT 514 // [LogPort] default syslog UDP port
#define SYS_LOG_LEVEL LOG_LEVEL_NONE // [SysLog]
#define SERIAL_LOG_LEVEL LOG_LEVEL_INFO // [SerialLog]
#define WEB_LOG_LEVEL LOG_LEVEL_INFO // [WebLog]
// – Ota -----------------------------------------
#define OTA_URL “http://domus1:80/api/arduino/” PROJECT “.ino.bin” // [OtaUrl]
// – MQTT ----------------------------------------
#define MQTT_USE 1 // [SetOption3] Select default MQTT use (0 = Off, 1 = On)
// !!! TLS uses a LOT OF MEMORY (20k) so be careful to enable other options at the same time !!!
//#define USE_MQTT_TLS // EXPERIMENTAL Use TLS for MQTT connection (+53k code, +20k mem) - Disable by //
// Needs Fingerprint, TLS Port, UserId and Password
#ifdef USE_MQTT_TLS
#define MQTT_HOST “m20.cloudmqtt.com” // [MqttHost]
#define MQTT_FINGERPRINT “A5 02 FF 13 99 9F 8B 39 8E F1 83 4F 11 23 65 0B 32 36 FC 07” // [MqttFingerprint]
#define MQTT_PORT 20123 // [MqttPort] MQTT TLS port
#define MQTT_USER “cloudmqttuser” // [MqttUser] Mandatory user
#define MQTT_PASS “cloudmqttpassword” // [MqttPassword] Mandatory password
#else
#define MQTT_HOST “domus1” // [MqttHost]
#define MQTT_PORT 1883 // [MqttPort] MQTT port (10123 on CloudMQTT)
#define MQTT_USER “DVES_USER” // [MqttUser] Optional user
#define MQTT_PASS “DVES_PASS” // [MqttPassword] Optional password
#endif
#define MQTT_BUTTON_RETAIN 0 // [ButtonRetain] Button may send retain flag (0 = off, 1 = on)
#define MQTT_POWER_RETAIN 0 // [PowerRetain] Power status message may send retain flag (0 = off, 1 = on)
#define MQTT_SWITCH_RETAIN 0 // [SwitchRetain] Switch may send retain flag (0 = off, 1 = on)
#define MQTT_STATUS_OFF “OFF” // [StateText1] Command or Status result when turned off (needs to be a string like “0” or “Off”)
#define MQTT_STATUS_ON “ON” // [StateText2] Command or Status result when turned on (needs to be a string like “1” or “On”)
#define MQTT_CMND_TOGGLE “TOGGLE” // [StateText3] Command to send when toggling (needs to be a string like “2” or “Toggle”)
#define MQTT_CMND_HOLD “HOLD” // [StateText4] Command to send when button is kept down for over KEY_HOLD_TIME * 0.1 seconds (needs to be a string like “HOLD”)
// – MQTT topics ---------------------------------
//#define MQTT_FULLTOPIC “tasmota/bedroom/%topic%/%prefix%/” // Up to max 80 characers
#define MQTT_FULLTOPIC “%prefix%/%topic%/” // [FullTopic] Subscribe and Publish full topic name - Legacy topic
// %prefix% token options
#define SUB_PREFIX “cmnd” // [Prefix1] Sonoff devices subscribe to %prefix%/%topic% being SUB_PREFIX/MQTT_TOPIC and SUB_PREFIX/MQTT_GRPTOPIC
#define PUB_PREFIX “stat” // [Prefix2] Sonoff devices publish to %prefix%/%topic% being PUB_PREFIX/MQTT_TOPIC
#define PUB_PREFIX2 “tele” // [Prefix3] Sonoff devices publish telemetry data to %prefix%/%topic% being PUB_PREFIX2/MQTT_TOPIC/UPTIME, POWER and TIME
// May be named the same as PUB_PREFIX
// %topic% token options (also ButtonTopic and SwitchTopic)
#define MQTT_TOPIC PROJECT // [Topic] (unique) MQTT device topic
#define MQTT_GRPTOPIC “sonoffs” // [GroupTopic] MQTT Group topic
#define MQTT_CLIENT_ID “DVES_%06X” // [MqttClient] Also fall back topic using Chip Id = last 6 characters of MAC address
// – MQTT - Telemetry ----------------------------
#define TELE_PERIOD 300 // [TelePeriod] Telemetry (0 = disable, 10 - 3600 seconds)
// – MQTT - Domoticz -----------------------------
#define USE_DOMOTICZ // Enable Domoticz (+6k code, +0.3k mem) - Disable by //
#define DOMOTICZ_IN_TOPIC “domoticz/in” // Domoticz Input Topic
#define DOMOTICZ_OUT_TOPIC “domoticz/out” // Domoticz Output Topic
#define DOMOTICZ_UPDATE_TIMER 0 // [DomoticzUpdateTimer] Send relay status (0 = disable, 1 - 3600 seconds) (Optional)
// – HTTP ----------------------------------------
#define USE_WEBSERVER // Enable web server and wifi manager (+66k code, +8k mem) - Disable by //
#define WEB_SERVER 2 // [WebServer] Web server (0 = Off, 1 = Start as User, 2 = Start as Admin)
#define WEB_PORT 80 // Web server Port for User and Admin mode
#define WEB_USERNAME “admin” // Web server Admin mode user name
#define WEB_PASSWORD “” // [WebPassword] Web server Admin mode Password for WEB_USERNAME (empty string = Disable)
#define FRIENDLY_NAME “Sonoff” // [FriendlyName] Friendlyname up to 32 characters used by webpages and Alexa
#define USE_EMULATION // Enable Belkin WeMo and Hue Bridge emulation for Alexa (+11k code, +2k mem)
#define EMULATION EMUL_NONE // [Emulation] Select Belkin WeMo (single relay/light) or Hue Bridge emulation (multi relay/light) (EMUL_NONE, EMUL_WEMO or EMUL_HUE)
// – mDNS ----------------------------------------
#define USE_DISCOVERY // Enable mDNS for the following services (+8k code, +0.3k mem) - Disable by //
#define WEBSERVER_ADVERTISE // Provide access to webserver by name .local/
#define MQTT_HOST_DISCOVERY // Find MQTT host server (overrides MQTT_HOST if found)
// – Time - Up to three NTP servers in your region
#define NTP_SERVER1 “pool.ntp.org” // [NtpServer1] Select first NTP server by name or IP address (129.250.35.250)
#define NTP_SERVER2 “nl.pool.ntp.org” // [NtpServer2] Select second NTP server by name or IP address (5.39.184.5)
#define NTP_SERVER3 “0.nl.pool.ntp.org” // [NtpServer3] Select third NTP server by name or IP address (93.94.224.67)
// – Time - Start Daylight Saving Time and timezone offset from UTC in minutes
#define TIME_DST North, Last, Sun, Mar, 2, +120 // Northern Hemisphere, Last sunday in march at 02:00 +120 minutes
// – Time - Start Standard Time and timezone offset from UTC in minutes
#define TIME_STD North, Last, Sun, Oct, 3, +60 // Northern Hemisphere, Last sunday in october 02:00 +60 minutes
// – Application ---------------------------------
#define APP_TIMEZONE 1 // [Timezone] +1 hour (Amsterdam) (-12 … 12 = hours from UTC, 99 = use TIME_DST/TIME_STD)
#define APP_LEDSTATE LED_POWER // [LedState] Function of led (LED_OFF, LED_POWER, LED_MQTTSUB, LED_POWER_MQTTSUB, LED_MQTTPUB, LED_POWER_MQTTPUB, LED_MQTT, LED_POWER_MQTT)
#define APP_PULSETIME 0 // [PulseTime] Time in 0.1 Sec to turn off power for relay 1 (0 = disabled)
#define APP_POWERON_STATE 3 // [PowerOnState] Power On Relay state (0 = Off, 1 = On, 2 = Toggle Saved state, 3 = Saved state)
#define APP_BLINKTIME 10 // [BlinkTime] Time in 0.1 Sec to blink/toggle power for relay 1
#define APP_BLINKCOUNT 10 // [BlinkCount] Number of blinks (0 = 32000)
#define APP_SLEEP 0 // [Sleep] Sleep time to lower energy consumption (0 = Off, 1 - 250 mSec)
#define KEY_HOLD_TIME 40 // [SetOption32] Number of 0.1 seconds to hold Button or external Pushbutton before sending HOLD message
#define SWITCH_MODE TOGGLE // [SwitchMode] TOGGLE, FOLLOW, FOLLOW_INV, PUSHBUTTON, PUSHBUTTON_INV, PUSHBUTTONHOLD, PUSHBUTTONHOLD_INV or PUSHBUTTON_TOGGLE (the wall switch state)
#define WS2812_LEDS 30 // [Pixels] Number of WS2812 LEDs to start with
#define TEMP_CONVERSION 0 // [SetOption8] Return temperature in (0 = Celsius or 1 = Fahrenheit)
#define TEMP_RESOLUTION 1 // [TempRes] Maximum number of decimals (0 - 3) showing sensor Temperature
#define HUMIDITY_RESOLUTION 1 // [HumRes] Maximum number of decimals (0 - 3) showing sensor Humidity
#define PRESSURE_RESOLUTION 1 // [PressRes] Maximum number of decimals (0 - 3) showing sensor Pressure
#define ENERGY_RESOLUTION 3 // [EnergyRes] Maximum number of decimals (0 - 5) showing energy usage in kWh
// – Sensor code selection -----------------------
#define USE_ADC_VCC // Display Vcc in Power status. Disable for use as Analog input on selected devices
                                             // WARNING: Select none for default one DS18B20 sensor or enable one of the following two options for multiple sensors
//#define USE_DS18x20 // Optional for more than one DS18x20 sensors with id sort, single scan and read retry (+1.3k code)
//#define USE_DS18x20_LEGACY // Optional for more than one DS18x20 sensors with dynamic scan using library OneWire (+1.5k code)
#define USE_I2C // I2C using library wire (+10k code, 0.2k mem) - Disable by //
#define USE_SHT // Add I2C emulating code for SHT1X sensor
#define USE_HTU // Add I2C code for HTU21/SI7013/SI7020/SI7021 sensor
#define USE_BMP // Add I2C code for BMP/BME280 sensor
#define USE_BH1750 // Add I2C code for BH1750 sensor
// #define USE_VEML6070 // Add I2C code for VEML6070 sensor (+0.5k code)
// #define USE_ADS1115 // Add I2C code for ADS1115 16 bit A/D converter based on Adafruit ADS1x15 library (library not needed) (+0.7k code)
// #define USE_ADS1115_I2CDEV // Add I2C code for ADS1115 16 bit A/D converter using library i2cdevlib-Core and i2cdevlib-ADS1115 (+2k code)
// #define USE_INA219 // Add I2C code for INA219 Low voltage and current sensor (+1k code)
#define USE_IR_REMOTE // Send IR remote commands using library IRremoteESP8266 and ArduinoJson (+4k code, 0.3k mem)
// #define USE_IR_HVAC // Support for HVAC system using IR (+2k code)
#define USE_IR_RECEIVE // Support for IR receiver (+5.5k code)
#define USE_WS2812 // WS2812 Led string using library NeoPixelBus (+5k code, +1k mem) - Disable by //
#define USE_WS2812_CTYPE 1 // WS2812 Color type (0 - RGB, 1 - GRB, 2 - RGBW, 3 - GRBW)
// #define USE_WS2812_DMA // DMA supports only GPIO03 (= Serial RXD) (+1k mem). When USE_WS2812_DMA is enabled expect Exceptions on Pow
#define USE_ARILUX_RF // Add code for Arilux RF remote controller (+0.8k code)
  • Compile a minimal version if upgrade memory gets tight ONLY TO BE USED FOR UPGRADE STEP 1!
  • To be used as step 1 during upgrade.
  • Step 2 is re-compile with option BE_MINIMAL commented out.
  • !!! Needed for next release of Arduino/ESP8266 (+22k code, +2k mem) !!!
//#define BE_MINIMAL // Minimal version if upgrade memory gets tight (-45k code, -2k mem)
  • No user configurable items below
#if defined(USE_MQTT_TLS) && defined(USE_WEBSERVER)
#error “Select either USE_MQTT_TLS or USE_WEBSERVER as there is just not enough memory to play with”
#endif
#endif // USER_CONFIG_H
