My goal is to use an USB wifi adapter as an access point on HA server to extend the range of my wifi network. The wifi router is far away the HA server gets the network on ethernet.
I have a fresh install of HA (haos_odroid-n2-9.3.img.xz) on an Odroid N2 (Linux core-ssh 5.15.74).
I also installed Hass.io, ESPhome and the ssh terminal add-ons.
I tried the same installation on an N2+ but the USB didn’t work at all on that (lsusb cannot lists more device after plugging in any usb device) so I moved to the N2 which is better a bit because lsusb lists my plugged usb wifi adapters (without name).
I tried four different wifi adapter but none of them worked. In the terminal I checked ifconfig but no wlan0 showed.
Plugging a Comfast (0bda:b812) wifi adapter in dmesg shows this:
usb 1-1.1: new high-speed USB device number 3 using xhci-hcd
88x2bu: loading out-of-tree module taints kernel.
usbcore: registered new interface driver rtl88x2bu
Plugging a Tenda (148f:7601) wifi adapter I get this from dmesg:
usb 1-1.2: new high-speed USB device number 7 using xhci-hcd
usb 1-1.2: reset high-speed USB device number 7 using xhci-hcd
mt7601u 1-1.2:1.0: ASIC revision: 76010001 MAC revision: 76010500
mt7601u 1-1.2:1.0: Firmware Version: 0.1.00 Build: 7640 Build time: 201302052146____
mt7601u 1-1.2:1.0: Vendor request req:07 off:09a8 failed:-110
mt7601u 1-1.2:1.0: Vendor request req:02 off:09a8 failed:-110
mt7601u 1-1.2:1.0: Vendor request req:07 off:0734 failed:-110
mt7601u 1-1.2:1.0: Vendor request req:42 off:0230 failed:-110
mt7601u 1-1.2:1.0: Vendor request req:07 off:0080 failed:-110
mt7601u 1-1.2:1.0: Vendor request req:02 off:0080 failed:-110
mt7601u: probe of 1-1.2:1.0 failed with error -110
usbcore: registered new interface driver mt7601u
The other two adapter (0bda:818b and 0846:9053) just get one line about plugging in.
usb 1-1.2: new high-speed USB device number 9 using xhci-hcd
I tried to shutdown/reboot after plugged in the wifi adapters, no luck either.
What should I do to get wlan0?
