Hi everybody,
I have linked a baikal
calendar to Home Assistant via webdav
integration. When I create an event externally (for example, via thunderbird
), it will show up in Home Assistant within a short period of time.
However, action: calendar.create_event
does not work with this calendar. I cannot even choose the calendar via actions
, the dropdown menu will only show the local_calendar
that is part of Home Assistant. If I manually enter it, like below, I get this error Die Aktion calendar.create_event konnte nicht ausgeführt werden. Entity calendar.baikal_ben does not support this service.
entity_id: calendar.baikal_ben
summary: Test
start_date_time: "2024-12-22 13:00:00"
end_date_time: "2024-12-22 14:00:00"
By the way, the same error occurs when trying to write to a nextcloud
calendar. Same as above. Reading works without issues, writing to calendar is not supported.
I thought that this might have been a nextcloud issue, that’s why I set up baikal, but now that they both cannot be written to, I assume it’s Home Assistant.
The webdav
integration doesn’t need much; URL, username, password (and SSL yes/no). Since I can read the calendar, the credentials must be correct.
Is this expected behavior, or can I change something so that I can automate creating events in baikal
(or nextcloud
Thank you in advance for your help
