I have created a small Z-wave network of three Fibaro smoke sensors. One failed for some reason and lost connection to the controller which I was not able to re-establish. After resetting the smoke sensor and adding it as a new node I now have a ghost node, the old node. I am not able to delete it from OZW admin (VNC). Please, can anyone help me how to delete this ghost node?
Raspberry Pi 4b
Aeotec ZW090 Gen5 EU
HassOS 4.12
Supervisor version 235
Mosquitto broker 5.1 (add-on)
OpenZWave 0.5.2 (add-on)
You can use a tool connecting your usb stick directly on your computer. The tool is called “Zensys tool” and you can find it on internet. After that, you will easily remove the failed node. Just be cautious on the tool because it can also harm your network or even worse, the stick itself.
