I followed the steps previously suggested in here,
Unfortunately, I don’t even have most of the suggested services running.
I am trying to remove HA completely and start over, but any time I install the docker back again, I see my user, and I would like to start from fresh(new user, etc.)
The steps to install and then uninstall I’ve made:
Install
sudo apt-get remove docker docker-engine [docker.io](http://docker.io/) containerd runc
sudo apt-get update
sudo apt-get install \
apt-transport-https \
ca-certificates \
curl \
gnupg-agent \
software-properties-common
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
sudo apt-key fingerprint 0EBFCD88
sudo add-apt-repository \
"deb [arch=amd64] https://download.docker.com/linux/ubuntu \
$(lsb_release -cs) \
stable"
sudo apt-get update
sudo apt-get install docker-ce docker-ce-cli containerd.io
sudo docker run --init -d --name="home-assistant" -e "TZ=America/New_York" -v /home/dvir/Documents/hub:/config --net=host homeassistant/home-assistant:stable
###Stop the docker then###
sudo docker-compose up -d
sudo docker-compose restart
Uninstall:
sudo systemctl stop hassio-supervisor.service ---> this service wasn't running
sudo systemctl stop hassio-apparmor.service---> this service wasn't running
sudo rm -rf /etc/systemd/system/hassio-supervisor.service ---> this folder didn't exist
sudo rm -rf /etc/systemd/system/hassio-apparmor.service ---> this folder didn't exist
sudo rm -rf /usr/sbin/hassio-supervisor---> this folder didn't exist
sudo rm -rf /usr/sbin/hassio-apparmor---> this folder didn't exist
sudo docker ps -a
sudo docker rm -f id
sudo docker images -a
sudo docker rmi id
Unfortunately, when I install the docker from scrach again, I see my previous user.
