I have just configured my Echo device to work with Home Assistant and all my devices are correctly discovered, but I am not able to customize them (name, filtering out some devices).
Whatever I do in the config, it looks like it makes no impact on Alexa Smart Home skills. Devices are still being discovered under their original names.
This is what I can see in the logs, when doing device discovery on Alexa App:
2018-08-30 23:31:30 INFO (MainThread) [homeassistant.core] Bus:Handling <Event alexa_smart_home[L]: request=namespace=Alexa.Discovery, name=Discover, response=namespace=Alexa.Discovery, name=Discover.Response>
2018-08-30 23:31:46 ERROR (MainThread) [homeassistant.components.cloud.iot] Error handling message
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cloud/iot.py", line 167, in _handle_connection
hass, self.cloud, msg['handler'], msg['payload'])
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cloud/iot.py", line 223, in async_handle_message
return (yield from handler(hass, cloud, payload))
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/cloud/iot.py", line 231, in async_handle_alexa
hass, cloud.alexa_config, payload)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/alexa/smart_home.py", line 732, in async_handle_message
response = await funct_ref(hass, config, request, context)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/alexa/smart_home.py", line 874, in async_api_entity_wrapper
return await funct(hass, config, request, context, entity)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/alexa/smart_home.py", line 1525, in async_api_reportstate
properties.extend(interface.serialize_properties())
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/alexa/smart_home.py", line 277, in serialize_properties
prop_value = self.get_property(prop_name)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/alexa/smart_home.py", line 413, in get_property
'value': float(temp),
TypeError: float() argument must be a string or a number, not 'NoneType'
