andyfsimon
(Andyfsimon)
January 19, 2021, 9:39pm
21
Could be a syntax problem - can you repost your code with the preformatted text tag (</>)?
This is mine:
mac: 'FF:FF:FF:FF:FF:F7'
host_name: leaf2016
source_type: gps
dev_id: leaf2016
gps:
- '{{ states(''sensor.leaf_position_lat'') | float | round(7) }}'
- '{{ states(''sensor.leaf_position_lon'') | float | round(7) }}'
gps_accuracy: 20
battery: '{{ states(''sensor.leaf_soc'') | round(0) }}'
Update: I noticed that I didn’t used the device_tracker.leaf2016 on the map, I actually made a person named “leaf” and associated the leaf2016 device tracker to it.
I can see the person.leaf in the map.
Riseley
(Riseley)
January 19, 2021, 10:13pm
22
- id: '1610996729565'
alias: Update Civic position
description: ''
- platform: state
entity_id: device_tracker.civic_position_latitude
- platform: state
entity_id: device_tracker.civic_position_longitude
condition: []
- service: device_tracker.see
mac: FF:FF:EE:FF:EE:FE
host_name: civic20152
source_type: gps
dev_id: civic20152
gps:
- '{{ states(''sensor.civic_position_latitude'') }}'
- '{{ states(''sensor.civic_position_longitude'') }}'
gps_accuracy: 20
mode: single
- id: '1611080901457'
alias: Update Civic T2 Position
description: ''
- platform: state
entity_id: device_tracker.civic_position_latitude2
- platform: state
entity_id: device_tracker.civic_position_longitude2
condition: []
mac: EE:EE:EE:FF:EE:21
host_name: civic20153
source_type: gps
dev_id: civic20153
gps:
- '{{ states(''sensor.civic_position_latitude2'') | float | round(7) }}'
- '{{ states(''sensor.civic_position_longitude2'') | float | round(7) }}'
gps_accuracy: 20
mode: single
andyfsimon
(Andyfsimon)
January 20, 2021, 6:28am
23
Uhm, what I don’t understand in your code is the trigger. Why do you use DEVICE_TRACKER.civic_position_* ? Shouldn’t be SENSOR.civic_position_* ?
The positional attributes of the device_tracker are fictional (you actually update them manually with this very automation) so you need to trigger the update whenever the sensors on you car change value.
Riseley
(Riseley)
January 21, 2021, 5:10pm
24
Hi Andy,
I have amended the code. However the automation is not being triggered since I made that change. Here is the current configuration and automation. This has been a real head scratcher…
device_tracker:
- platform: mqtt
devices:
civic_position_latitude: 'civic/position/latitude'
civic_position_longitude: 'civic/position/longitude'
- platform: mqtt
devices:
civic_position_latitude2: 'civic/position/latitude2'
civic_position_longitude2: 'civic/position/longitude2'
description: ''
- platform: state
entity_id: sensor.civic_position_latitude
- platform: state
entity_id: sensor.civic_position_longitude
condition: []
source_type: gps
dev_id: civic20152
gps:
- '{{ states(''sensor.civic_position_latitude'') | float | round(7) }}'
- '{{ states(''sensor.civic_position_longitude'') | float | round(7) }}'
gps_accuracy: 20
battery: 100
mode: single
description: ''
- platform: state
entity_id: sensor.civic_position_latitude2
- platform: state
entity_id: sensor.civic_position_longitude2
condition: []
source_type: gps
dev_id: civic20153
gps:
gps_accuracy: 20
battery: 100
mode: single
You are missing automation: at the top of the automation.
Riseley
(Riseley)
January 25, 2021, 5:02pm
26
I have now got this to work correctly. This is because I had not defined sensors correctly in configuration.yaml
Thank you for your assistance. I am including my set up for reference purposes:
Configuration.yaml:
- platform: mqtt
state_topic: "civic/position/latitude"
name: civic position lat
- platform: mqtt
state_topic: "civic/position/longitude"
name: civic position longitude
- platform: mqtt
automations.yaml
- id: '1611426245259'
alias: NA4
description: ''
- platform: state
- platform: state
condition: []
mac: AA:AA:AA:AA:AA:AA
host_name: civic
source_type: gps
dev_id: civic
gps:
- '{{ states(''sensor.civic_position_lat'') }}'
gps_accuracy: 20
battery: 100
mode: single
/config/known.devices.yaml:
civic:
icon:
picture:
track: true
hi
i have a similar problem
i receive the json data
{“sensor”:“gps”}{“time”:10580500}[{“longitude”:-9.546621},{“latitude”:50.34518}
and i try to show on a map card
this is my configuration.yaml
- platform: mqtt
name: "Garua GPS Time"
state_topic: "datos_gps/sensor/garua/state"
unit_of_measurement: "s"
value_template: "{{ value_json.time }}"
- platform: mqtt
name: "Garua GPS Latitude"
unit_of_measurement: "°"
value_template: "{{ value_json.latitude }}"
- platform: mqtt
name: "Garua GPS Longitude"
value_template: "{{ value_json.longitude }}"
this my automations.yaml file
- id: my_gpsdata
alias: 'Update Leaf position'
- platform: state
entity_id: sensor.garua_gps_latitude
- platform: state
entity_id: sensor.garua_gps_longitude
condition: []
# Linea 184
host_name: barco
dev_id: barco
source_type: gps
gps:
- '{{ states(''sensor.garua_gps_latitude'') }}'
- '{{ states(''sensor.garua_gps_longitude'') }}'
mode: single
i have an error when i try the code
Dont think that should be there ?
Hellis81
(Hellis81)
July 28, 2021, 11:17am
29
You have a [ in the middle there…
That suggests to me that is an array.
What does your sensors look like? Do they show lat and lon?
Remember to mask the real data
sorry this line is commented
i reedit the code
this is the entity in the states page
[sensor.garua_gps_latitude] 50.34518 unit_of_measurement: °
friendly_name: Garua GPS Latitude
Hellis81
(Hellis81)
July 28, 2021, 11:38am
32
That makes no sense. Because the json you say you get is not valid.
This is valid:
{"sensor":"gps"},{"time":10580500},[{"longitude":-9.546621},{"latitude":50.34518}]
Notice there is commas between the values and a ending ]
And this is also valid:
{"sensor":"gps"},{"time":10580500},{"longitude":-9.546621},{"latitude":50.34518}
But in order to get lon and lat you would need to access item [2][“longitude”]
or if there should be [ ] also [2][0][“longitude”]
If the json looks like this:
{"sensor":"gps","time":10580500,"longitude":-9.546621,"latitude":50.34518}
Then it would make sense.
this is my new json
[{"sensor":"gps"},{"longitude":-7.65456},{"latitude":50.64512}]
but now my sensor can’t see the value data
this are my data parser from json, and i try to show in a map
There is no way to see the gps data received on the map
Does anybody have an idea?
Invalid config for [automation]: [action] is an invalid option for [automation]. Check: automation->trigger->0->action.
my configuration.yaml is not valid
automation:
- trigger:
platform: state
entity_id: sensor.kia_position_lat, sensor.kia_position_long
data_template:
dev_id: ship
gps:
- "{{ states('sensor.kia_position_lat') }}"
- "{{ states('sensor.kia_position_long') }}"
Hellis81
(Hellis81)
July 30, 2021, 10:21am
38
You have indentation errors.
Action is not a part of trigger.
davidzzgit
(Davidzzgit)
September 7, 2021, 7:55am
39
Thank you
it’s running fine
