I installed Mosquitto MQTT via the supervisor AddOns in HomeAssistant. I want to create a bridge connection (following this thread) and it says to create an additional .conf
file in /etc/mosquitto/conf.d/
directory
When I SSH into my HA device, there is no /etc/mosquitto
directory. Yes when I view the logs for Moquitto on HA it shows that it’s loading from that directory. Is that in some container I don’t have access to ?
[20:10:36] INFO: Setup mosquitto configuration
[20:10:36] WARNING: SSL not enabled - No valid certs found!
[20:10:36] INFO: No local user available
[20:10:37] INFO: Initialize Hass.io Add-on services
[20:10:37] INFO: Initialize Home Assistant discovery
[20:10:37] INFO: Start Mosquitto daemon
1609819837: mosquitto version 1.6.3 starting
1609819837: Config loaded from /etc/mosquitto.conf.
