Cannot fix Nest configuration
I am trying to add Nest to my home assistant.
While I was going through the initial configuration to add the integration, I accidentally put in the wrong oAuth code and now I cannot go back to change the code, it only allows me to continue from where I got up to, I have tried restarting homeassistant and cannot figure out how to head back to fix my error. Does anyone know where that configuration is stored so I can fix it? I cannot complete the configuration because when I put in the Device Access Project ID, it says ‘Can’t link to [project name]’ and won’t allow me to finishing configuring the integration to the delete it and restart.
Any recommendations would be greatly appreciated.
May be a long shot, but go to Settings/Devices & Services. Click on the 3 dots on the upper right and corner and click on Application Credentials. See if you have one for Nest Integration. If so, delete it. Then try to re-add the integration.
I think I read your post right.
