I am new to HA, I have been using Smart things for years, I tried the Zooz S2 stick as well as the Aeotec Z-Stick Gen5+ but I cannot get any Z-wave devices to pair. When I remove them from SmartThings and exclude them from the Z-wave utilities. I even unplug the smart things hub. Did the factory reset on the GE switch (3x up, 3x down) until I get the blue flashing, even cycled power at the breakers, but I cannot get this switch to pick up my either the Zooz or the Aeotec through the Z-Wave JS or through the integration screens. I even moved my raspberry Pi4 4 right next to the switch to see if that helps. If I do the manual pair on the Aeotec it pairs instantly, but when I plug the stick back in, it picks up the switch, but it has a red unhappy face sayings its dead and the interview never gets past “Protocolinfo” if I go through the logs I see this, so it see it
2023-05-19T22:45:04.467Z CNTRLR « [Node 005] received response for protocol info:
basic device class: Routing Slave
generic device class: Multilevel Switch
specific device class: Multilevel Power Switch
node type: End Node
is always listening: true
is frequent listening: false
can route messages: true
supports security: false
supports beaming: true
maximum data rate: 100000 kbps
protocol version: 3
2023-05-19T22:45:04.472Z CNTRLR [Node 005] Interview stage completed: ProtocolInfo
2023-05-19T22:45:04.474Z CNTRLR » [Node 005] pinging the node...
2023-05-19T22:45:04.496Z SERIAL » 0x010800130501002503c6 (10 bytes)
2023-05-19T22:45:04.500Z DRIVER » [Node 005] [REQ] [SendData]
│ transmit options: 0x25
│ callback id: 3
└─[NoOperationCC]
2023-05-19T22:45:04.514Z SERIAL « [ACK] (0x06)
2023-05-19T22:45:04.520Z SERIAL « 0x0104011301e8 (6 bytes)
2023-05-19T22:45:04.522Z SERIAL » [ACK] (0x06)
2023-05-19T22:45:04.527Z DRIVER « [RES] [SendData]
was sent: true
2023-05-19T22:45:10.533Z SERIAL « 0x011800130301025b007f7f7f7f7f0100070000000002030000d7 (26 bytes)
2023-05-19T22:45:10.539Z SERIAL » [ACK] (0x06)
2023-05-19T22:45:10.545Z DRIVER « [REQ] [SendData]
callback id: 3
transmit status: NoAck, took 6030 ms
routing attempts: 3
protocol & route speed: Z-Wave, 40 kbit/s
TX channel no.: 0
2023-05-19T22:45:10.557Z CNTRLR [Node 005] The node did not respond after 1 attempts, it is presumed dead
Also, I can re include this switch to Smart things with out any issues? I have been stuck on this for a few days now! I really want to get rid of my smart things hub, but I have ~30 Z wave devices in my house! I have also tried a set of blinds and a Jasco version of the switch with no luck. Any ideas of next steps?
