I’m currently trying to setup a hassio addon that contains the deCONZ software for the Raspbee shield. I’m already pretty familiar with Docker and somewhat with the config.json and build.json
I’ve gotten as far that I have a running Docker image in hassio (build locally) and connected the GPIO and the needed devices from the host to the docker image using the configuration. So I am able to run the deCONZ software and it recognizes the Raspbee shield. So I was happy with that.
The issue is that the deCONZ software creates an SQLLite database file in the container, which of course gets erased upon restart. I know that hassio supports a map in the configuration to link host directories to the docker image, but I cannot get it to work.
In the docker file I’m exposing two volumes, being:
VOLUME ["/share", "/config"]
The build.json contains the following
"build_from": {
"aarch64": "arm64v8/debian:stretch",
"amd64": "debian:stretch",
"armhf": "arm32v7/debian:stretch",
"i386": "i386/debian:stretch"
What I’ve got in the config.json is:
"name": "deCONZ",
"version": "1.0b-1",
"slug": "deconz",
"description": "A Hass.io compatible installation of the program for the Zigbee rpi shield created by www.dresden-elektronik.de",
"startup": "services",
"boot": "auto",
"map": [
"addons:rw",
"backup:rw",
"config:rw",
"share:rw",
"ssl:rw"
"options": {},
"schema": {},
"url": "https://bitbucket.org/jongsoftdev/hassio-addon/overview",
"ports": {
"8080/tcp": 8080,
"443/tcp": 443,
"3389/tcp": 3389
"gpio": true,
"devices": [
"/dev/ttyAMA0:/dev/ttyAMA0:rw"
"webui": "http://[HOST]:[PORT:8080]"
I would expect the share and config to be mapped to ‘/share’ and ‘/config’. But they are not and I cannot figure out why? Can someone help with this.
