After so long creating my scripts and automations etc, I’ve decided to start out on developing my dashboard and I’m probably doing something wrong but I’m stuck right at the beginning and cannot get my locally stored image to show on the dashboard background. NOTE: I have used a 3rd party theme (copy and pasted to my own theme file) as my basis, to edit and personalise.
I have:
configuration.yaml
frontend:
themes: !include_dir_merge_named themes
/config/themes/my_theme/my_theme.yaml
my_theme:
# Global
background-image: center / cover no-repeat fixed url(/local/images/dark-blur-bg.png)
lovelace-background: var(--background-image)
primary-color: "#209cee"
light-primary-color: "#B6B6C1"
primary-background-color: "#212121"
secondary-background-color: rgba(25, 25, 25, 0.7)
divider-color: var(--primary-background-color)
accent-color: rgba(255, 159, 9, 1)
And using the raw config editor in my dashboard:
- title: Home
theme: my_theme
background-image: center / cover no-repeat fixed url('/local/images/dark-blur-bg.png')
cards:
- type: entity
entity: sensor.disk_use_percent
It’s my first attempt at this, so what am I doing wrong?
**EDIT - I only want this theme in one particular dashboard, and not all of HA, so I have not selected my_theme
in Profile > Theme
