Jeez, I have been trying to get automation (my 1st one so I’m also learning) to work.
I have a generic thermostat entity (is that the right term, a widget on the dashboard to set temp) and a group of entities for a smart TRV. The group includes a slider to set the desired temp. The group is really for diagnostics but I want my thermostat to “send” its setting to the slider (which in turn sends an mqtt message to the TRV). All works bar the thermostat send to slider. The HA log file says:
WARNING (MainThread) [homeassistant.components.input_number] Invalid value: 0.0 (range 10.0 - 23.0)
Irrespective of whatever value I use on the circular dial on the generic thermostat. What on earth is wrong?
# configuration.yaml
climate:
- platform: generic_thermostat
heater: switch.danfoss_rxz3_rf_relay_switching_unit_switch_2
target_sensor: sensor.lounge_temperature
# sensors.yaml -- my own file and I have the !include directive that works.
- platform: mqtt
state_topic: "/energenie/eTRV/Report/Temperature/8008"
name: "Lounge Temperature"
unit_of_measurement: "°C"
force_update: true
expire_after: 660
- platform: mqtt
state_topic: "/energenie/eTRV/Report/TargetTemperature/8008"
name: "Lounge Target Rcvd"
- platform: mqtt
state_topic: "/energenie/eTRV/Report/Voltage/8008"
name: "Lounge TRV Voltage"
unit_of_measurement: V
force_update: true
- platform: mqtt
state_topic: "/energenie/eTRV/Command/ValveState/8008"
- platform: mqtt
state_topic: "/energenie/eTRV/Command/Temperature/8008"
- platform: statistics
entity_id: sensor.lounge_temperature
max_age:
minutes: 25
binary_sensor:
- platform: mqtt
state_topic: "/energenie/eTRV/Report/Diagnostics/8008"
name: "Lounge TRV Motor current below expectation"
value_template: '{{ value_json["Motor current below expectation"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV Motor current always high"
value_template: '{{ value_json["Motor current always high"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV Motor taking too long"
value_template: '{{ value_json["Motor taking too long"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV discrepancy between air and pipe sensors"
value_template: '{{ value_json["discrepancy between air and pipe sensors"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV air sensor out of expected range"
value_template: '{{ value_json["air sensor out of expected range"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV pipe sensor out of expected range"
value_template: '{{ value_json["pipe sensor out of expected range"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV Low Power Mode Enabled"
value_template: '{{ value_json["low power mode is enabled"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV no target temperature has been set by host"
value_template: '{{ value_json["no target temperature has been set by host"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV valve may be sticking"
value_template: '{{ value_json["valve may be sticking"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV valve exercise was successful"
value_template: '{{ value_json["valve exercise was successful"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV valve exercise was unsuccessful"
value_template: '{{ value_json["valve exercise was unsuccessful"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV driver micro has suffered a watchdog reset and needs data refresh"
value_template: '{{ value_json["driver micro has suffered a watchdog reset and needs data refresh"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV driver micro has suffered a noise reset and needs data refresh"
value_template: '{{ value_json["driver micro has suffered a noise reset and needs data refresh"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV battery voltage has fallen below 2.2V and valve has been opened"
value_template: '{{ value_json["battery voltage has fallen below 2p2V and valve has been opened"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV request for heat messaging is enabled"
value_template: '{{ value_json["request for heat messaging is enabled"] }}'
payload_on: true
payload_off: false
- platform: mqtt
name: "Lounge TRV request for heat"
value_template: '{{ value_json["request for heat"] }}'
payload_on: true
payload_off: false
# THIS IS THE ENTITY I AM TRYING TO SET
input_number:
lounge_temp:
name: Lounge Temperature Target
min: 10
max: 23
step: 1
mode: slider
initial: 18
icon: mdi:thermometer-lines
input_select:
lounge_trv_state:
name: Lounge TRV Valve State
options:
- Closed
- Normal
- Open
automation 8008:
- alias: Temp slider
initial_state: true
hide_entity: true
platform: state
entity_id: input_number.lounge_temp
service: mqtt.publish
data_template:
topic: '/energenie/eTRV/Command/Temperature/8008'
retain: true
payload: "{{ states('input_number.lounge_temp') | int }}"
script:
send_report_voltage_lounge:
sequence:
- service: script.send_trv_command
command: 'Voltage'
send_report_diagnostics_lounge:
sequence:
command: 'Diagnostics'
send_exercise_lounge:
sequence:
command: 'Exercise'
send_identity_lounge:
sequence:
# This is written using the Script Syntax
command: 'Identify'
#script:
send_trv_command:
sequence:
- service: mqtt.publish
data_template:
topic: '/energenie/eTRV/Command/{{command}}/{{id}}'
payload: 'ON'
group:
lounge_trv:
#control: hidden
entities:
- sensor.lounge_temperature
- input_number.lounge_temp
- sensor.lounge_target_rcvd
- input_select.lounge_trv_state
# - switch.lounge_trv_low_power_mode
- script.send_report_diagnostics_lounge
- script.send_exercise_lounge
- script.send_identity_lounge
- script.send_report_voltage_lounge
- sensor.lounge_trv_voltage
lounge_diagnostics:
control: hidden
entities:
- binary_sensor.lounge_trv_motor_current_below_expectation
- binary_sensor.lounge_trv_motor_current_always_high
- binary_sensor.lounge_trv_motor_taking_too_long
- binary_sensor.lounge_trv_discrepancy_between_air_and_pipe_sensors
- binary_sensor.lounge_trv_air_sensor_out_of_expected_range
- binary_sensor.lounge_trv_pipe_sensor_out_of_expected_range
- binary_sensor.lounge_trv_low_power_mode_enabled
- binary_sensor.lounge_trv_no_target_temperature_has_been_set_by_host
- binary_sensor.lounge_trv_valve_may_be_sticking
- binary_sensor.lounge_trv_valve_exercise_was_successful
- binary_sensor.lounge_trv_valve_exercise_was_unsuccessful
- binary_sensor.lounge_trv_driver_micro_has_suffered_a_watchdog_reset_and_needs_data_refresh
- binary_sensor.lounge_trv_driver_micro_has_suffered_a_noise_reset_and_needs_data_refresh
- binary_sensor.lounge_trv_battery_voltage_has_fallen_below_2_2v_and_valve_has_been_opened
- binary_sensor.lounge_trv_request_for_heat_messaging_is_enabled
# automations.yaml
- alias: 'Lounge temp automate'
platform: state
entity_id: climate.Lounge
service: input_number.set_value
entity_id: input_number.lounge_temp #-- This is the entity from above in my sensors.yaml
data_template:
# Automation works in the sense that when I change the thermostat temp
# this automation runs.
# However ,
# This line, just sends 0.0 every time ??.
value: "{{ states.to_state.temperature | float }}" ## Also tried to_state.state , didnt work either.
As I say, it all works, ALMOST.
The thermostat correctly turns on the boiler if needed.
The slider in the group of sensors works and set the TRV via mqtt
All TRV readings are correct
Just cannot for love or moeny, get the thermostat to send its value to the input_number entity.
