Hallo all,
I am trying to split my config up into different folders. My configuration.yaml has the following contents:
homeassistant:
latitude: !secret latitude
longitude: !secret longitude
elevation: !secret elevation
unit_system: metric
time_zone: Europe/Amsterdam
packages: !include_dir_named integrations
My integrations folder have the following files:
integrations
├── cast.yaml
├── circadian_lighting.yaml.bak
├── config.yaml
├── device_tracker.yaml
├── frontend.yaml
├── history.yaml
├── light.yaml
├── lovelace.yaml
├── map.yaml
├── mobile_app.yaml
├── mqtt.yaml
├── person.yaml
├── recorder.yaml
├── sensor.yaml
├── sun.yaml
├── switch.yaml
├── system_health.yaml
├── utility_meter.yaml
├── vacuum.yaml
└── weather.yaml
0 directories, 20 files
With device_tracker.yaml only containing:
device_tracker:
With this setup, the device_tracker.see service is not available. It does become available when I edit my configuration.yaml to contain the device_tracker setup:
homeassistant:
unit_system: metric
device_tracker:
I tried removing every entity I could and tried to eliminate what happens if I eliminate certain files. However, I could not figure out a pattern. Furthermore, if I run
hass-script check_config -c /path/to/config -i device_tracker
on the configuration that does not expose the device_tracker.see service. I get the output:
Successful config (partial)
device_tracker:
However, I do not see the device_tracker being loaded in the logs when I run this configuration. So I am a bit stumped since all other stuff from the configuration seems to run fine. Is there something I am overlooking at the moment?
