I have been trying to get Ffmpeg running on my home assistant. I am fairly new to home assistant and my understanding of it is very limited at the moment as I’m still learning. I am wanting to add my rtsp streams. I can do this through the homekit integration, but I would like to keep them seperate. I have been following the information supplied on the home assistant ffmpeg website, but I cannot install/excute the commands it states. My system is not debian, so the debian backend commands wont help. I also cannot execute apt commands. I have gone on the ffmpeg website and attempted to install it from the snapshots, but none of them are accepted by my home assistant. I am sure there is a simple solution to this, but I need help please. I cannot seem to add as repository on app store, nor custom repo on hacs. I do not have a directory that is usr/bin/ffmpeg and adding the following to my configuration.yaml yeilded no results.
ffmpeg:
ffmpeg_bin: /usr/bin/ffmpeg
Thank you for any help
System Health
version: core-2021.4.6
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
virtualenv: false
python_version: 3.8.7
os_name: Linux
os_version: 5.4.83-v8
arch: aarch64
timezone: Australia/Melbourne
GitHub API: ok
Github API Calls Remaining: 4970
Installed Version: 1.11.3
Stage: running
Available Repositories: 776
Installed Repositories: 5
logged_in: true
subscription_expiration: May 21, 2021, 10:00 AM
relayer_connected: true
remote_enabled: true
remote_connected: true
alexa_enabled: true
google_enabled: true
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: undefined
host_os: Home Assistant OS 5.13
update_channel: stable
supervisor_version: supervisor-2021.04.0
docker_version: 19.03.15
disk_total: 234.0 GB
disk_used: 4.8 GB
healthy: true
supported: true
board: rpi4-64
supervisor_api: ok
version_api: ok
installed_addons: File editor (5.2.0), SSH & Web Terminal (8.2.0), Samba share (9.3.1), Duck DNS (1.12.5), HassOS I2C Configurator (0.13), HassOS Serial Configurator (0.5), HassOS SSH port 22222 Configurator (0.8), ArgonOne Active Cooling (20), AppDaemon 4 (0.6.0), Visual Studio Code (3.3.0), VLC (0.1.2)
dashboards: 1
resources: 2
mode: storage
