So have tried several things to get floorplan to show and at first, just wanted to use the examples built in. My main config looks like:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: https://xxxxx.duckdns.org
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
#ring:
#username: !secret ringu
#password: !secret ringp
ffmpeg:
stream:
# Sensors
# Weather prediction
- platform: yr
# - platform: ring
# scan_interval: 60
- platform: aarlo
monitored_conditions:
- last_capture
- total_cameras
- battery_level
- captured_today
- signal_strength
light:
- platform: mqtt
command_topic: 'light/double_garage'
optimistic: true
switch:
- platform: mqtt
name: Living Area Fan
command_topic: 'switch/living_area_fan'
optimistic: true
retain: false
# Text to speech
tts:
- platform: google_translate
#secrets: !include secrets.yaml
# Enables the frontend
frontend:
themes: !include themes.yaml
extra_html_url:
- /local/custom_ui/state-card-floorplan.html
resources:
- type: module
- url: /local/battery-entity.js?v=0.2
# - critical
# - warning
panel_custom:
- name: floorplan
sidebar_title: Floorplan
sidebar_icon: mdi:home
url_path: floorplan
config: !include floorplan.yaml
binary_sensor:
- platform: mqtt
state_topic: dummy/floorplan/sensor
# - platform: ring
# scan_interval: 60
- platform: aarlo
- motion
# - sound
# - ding
homeassistant:
customize:
binary_sensor.floorplan:
custom_ui_state_card: state-card-floorplan
# camera: !include camera.yaml
group: !include groups.yaml
#automation: !include automations.yaml
script: !include scripts.yaml
#customize: !include customize.yaml
#panel_custom: !include panel_custom.yaml
#binary_sensors: !include binary_sensors.yaml
hacs:
token: 0a34b727ce9ae4eb4574e31207f0b3621884cde5
aarlo:
username: !secret arlo_username
password: !secret arlo_password
packet_dump: True
db_motion_time: 30
db_ding_time: 10
recent_time: 10
last_format: '%m-%d %H:%M'
conf_dir: /config/.aarlo
no_media_upload: True
mode_api: auto
refresh_devices_every: 0
http_connections: 5
http_max_size: 10
camera:
- platform: ring
ffmpeg_arguments: '-pred 1 -q:v 2'
- platform: aarlo
# - platform: generic
# still_image_url: http://192.168.1.71/IMAGE.JPG?cidx=1612157614
- platform: generic
name: New York Broadway
still_image_url: 'http://archives.earthcam.com/archives5/ecnetwork/us/ny/nyc/tsmpr/archive10/live2.jpg'
As you can see in these screenshots, I have all of the files in place where I thought they should be.
Where am I going wrong with this? Have watched Dr. Z’s video and looked at the github repo and while I initially wanted to do as a panel, tried with lovelace card to without any luck.
