I am trying to get Glances data imported into InfluxDB. have searched all forums and followed Frenk’s youtube tutorial, but i still dont see any measurements under glances.autogen in influxdb.
Please can anybody help.
Setup: Installed Glances add-on and InfluxDB addon
InfluxDB:
Config:
After adding the integration, the integration page should show a glances box and say X amount of entities. You may need to click the entities and enable them.
Without the integration there are no entities, If there are no entities there will be nothing to save. Sensors created by integration.
did you ever get this working?
Mine works, and the difference I have is I have “enabled: true”
Looks like you have the function to push data to influx turned off.
I just tested my config, as i have forgotten how I did it, after following frenks video a while ago. I set it to false, and data stopped flowing, so I think that is your problem.
What I have realised from this post, is that I am taking the glances info into influx, using the addon config, and I am also using the integration to get the entities in HA. and then pushing all HA into influx also, which means I have glances info in influx twice. Good spotting that these are separate. Now I have changed my Grafana dashboards to the HA entities, and disabled my glances/influx data flow, and my processor has dropped 5% and my database is smaller. good outcome. dont need it there twice.
