Hi
I installed appdaemon on my ubuntu VM which is already running home assistant
I done sudo pip3 install appdaemon
Then created a config file in /home/homeassistant/conf (this not not wher emy HASS is, but i created it as per guide)
Here is my config
AppDaemon:
logfile: STDOUT
errorfile: STDERR
threads: 10
cert_path: /home/has/fullchain.pem
cert_verify: True
time_zone: <time zone>
# app_dir: /etc/appdaemon/apps
HASS:
ha_url: https://homeassistant.local:8123
ha_key: MYHASPW
# Apps
hello_world:
module: hello
class: HelloWorld'
When running i get
has@homeassistant:/home/homeassistant/conf$ appdaemon -c /home/homeassistant/conf
2017-07-31 10:26:56.973015 INFO AppDaemon Version 2.0.8 starting
2017-07-31 10:26:56.973167 INFO Configuration read from: /home/homeassistant/conf/appdaemon.yaml
/home/has/.local/lib/python3.5/site-packages/requests/packages/urllib3/connection.py:344: SubjectAltNameWarning: Certificate for homeassistant.local has no `subjectAltName`, falling back to check for a `commonName` for now. This feature is being removed by major browsers and deprecated by RFC 2818. (See https://github.com/shazow/urllib3/issues/497 for details.)
2017-07-31 00:26:57.038551 INFO Got initial state
2017-07-31 00:26:57.039062 INFO App initialization complete
2017-07-31 00:26:57.039376 INFO Dashboards are disabled
2017-07-31 00:26:57.058051 WARNING Disconnected from Home Assistant, retrying in 5 seconds
Im a total noob, so any help would be appreciated, and if i need to change anything could you please assist with the commands involved, thank you
