With hagenuck1’s code, I got it to work… at least somehow.
Because the raspberry pi shuts down as I want but I still get an error in my log:
Error running command: `ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -i /config/ssh/id_rsa [email protected] "sudo poweroff"`, return code: 255
However I got the solution!
This excellent article guided me: “A thorough guide on controlling anything SSH with Homeassistants’s Hass.io” by Dovydas Gulbinas, a software engineer with fullstack & DevOps tendencies
I didn’t follow the guide “to the letter” because unlike him I couldn’t create a user on my pi installation. Therefore I did it with the user root.
Here is how I did it:
You have to copy the public key of the computer from which you want to access the hassio host (Home Assistant Web UI).
list all the public keys you have by doing (If you have none, create one):
ls ~/.ssh/*.pub
Show public key
cat ~/.ssh/id_rsa.pub
Copy the public key, paste it into Sublime Text.
Save with Encoding Western Windows-1252
as authorized_keys
(no extension)
Copy authorized_keys
to a Fat 32 formatted USB. Plug the USB into your Hass.io device.
From the Home Assistant Web UI, navigate to the hass.io system page and choose “Import from USB”. (There will be no feedback, but that’s fine.)
On the MASTER computer:
You should then be able to SSH into your Hass.io device. On Mac/Linux, use:
ssh [email protected] -p 22222
(Tip: Learn more about this in the article on SSH access to the host for HassOS based Hass.io)
In the Hass.io CLI type “login
” in order to access the host system.
login
List all docker containers. The one we need has the name homeassistant
docker ps -a
CONTAINER ID |
IMAGE |
NAMES |
e547e79d00fb |
homeassistant/raspberrypi3-homeassistant:0.103.6 |
homeassistant |
Copy the CONTAINER ID.
docker exec -it e547e79d00fb /bin/bash
now finally generate your SSH key, but this time in a different directory
mkdir /config/ssh
ssh-keygen -t rsa -f /config/ssh/id_rsa
lets checkout our two brand new PUBLIC & PRIVATE keys
cd /config/ssh
ls -al
cat id_rsa.pub
if all went well you public key output should look something like this:
AAAAB3NzaC1[…]Bs= [email protected]
Copy this value for later use.
On the SLAVE computer:
SSH into the machine you want to control.
(In the original guide, Dovydas created a user. However, since I use a Single Board Computer with an openmediavault OS, it didn’t work with a user as described in the original guide. Therefore I did it with root
Generate key
ssh-keygen -t rsa
You can look at the key
Okay we have our keys setup but what about passwordless connection from the MASTER computer?
It’s easy we have to add the the public key we copied before to the authorized_keys
file of the SLAVE computer.
(Notice: the public key is much longer, I’ve shortened it for this guide with “[…]”)
echo "ssh-rsa AAAAAB3NzaC1[…]Bs= [email protected] " >> ~/.ssh/authorized_keys
(Notice: Opposed to the original guide I did not do chmod 600 ~/.ssh/authorized_keys
, because I didn’t want to mess with the unix permissions on the root account of my openmediavault OS installation.)
To run some commands with sudo without a password you need to add these lines to /etc/sudoers
file.
sudo visudo
Under the line %sudo ALL=(ALL:ALL) ALL
type:
root ALL=(ALL) NOPASSWD: ALL
(Notice: Since I am root, I don’t know if this is necessary in my case)
Save the file with ^O
(Ctrl+O).
Important! Delete the .tmp
from the file name in order to overwrite the file!
Exit the vi editor with ^X
(Ctrl+X).
Testing SSH connection from the MASTER computer to the SLAVE computer.
login
ssh -i /config/ssh/id_rsa -o StrictHostKeyChecking=no [email protected] 'sudo poweroff'
This should shut down the SLAVE computer.
Now it’s time to do the same thing in homeassistant.
Create a switch
in configuration.yaml
switch:
- platform: command_line
switches:
test_ssh:
command_on: "ssh -i /config/ssh/id_rsa -o StrictHostKeyChecking=no [email protected] 'sudo poweroff'"
friendly_name: Magic Test Switch
Restart the homeassistant server (Configuration > Server Controls > Restart)
Add an entity card
to Lovelace with the entity: switch.test_ssh
Now you’re ready to go!
