Cannot get location to work correctly
I am very new to all this, but have used the Pi Image to a micro SD, connected and can log in etc. I have installed the SSH and can connect to the Pi.
When opening HA I see the Moon instead of the Sun and the time is behind.
I have checked the date and time on the Pi and it is correct for my timezone and location and I have entered the correct Latitude, Longitude and Height above sea level in configuration.yaml as well as the correct Time Zone.
I have even tried a complete reboot of the Pi, as a last resort, but again the indicator is incorrect. I’m unsure what I should see when I select the Map section, but if it is supposed to show my location then this in not happening also as it shows me somewhere in the Atlantic Ocean and I’m actually in Australia.
If anyone can give me some suggestions it would be appreciated.
Ian
It does seem to suggest that you have a mistake in your lat/long entry I would doublecheck they are 100% correct, easiest way to find the correct lat/long coordinates is to use google maps, find your location then right click and select ‘what is here’ and it will give you the exact coordinates, elevation is used to calculate sunrise/sunset timings for your exact location. If you have entered correct lat/long then the map will show your location correctly.
I suspect you’re missing a ‘-’ off the start of one of your coordinates
Thanks for the suggestions, but I think my initial problem was that I did not wait long enough or it needed a couple of reboots, I checked all the coordinates and they were correct, I played around for a couple of hours trying to get this to work but could not. On leaving it until this morning, I now find that the map is showing and showing the correct location, so it would appear it just took a long time for it to work.
Thanks for the suggestions, now to add the other things I need over the next several weeks, one thing at a time, so I don’t try and do stupid things. Still on a steep learning curve here.
Ian
Glad you got it sorted :+1:
