Cannot get python to work in my HA setup
Can someone help me setup a really simple python script that writes to a text file in my homeassistant folder? I can’t get this simple action to work. Wondering if I am missing some installation components.
I haven’t gotten into Python scripts in HA yet, but the typical way to write a text file to disk in Python is:
with open('my_file_path', 'w') as file:
  file.write('My text.')
Followed this:
You can use the Home Assistant automation feature to achieve this. Below is a simple YAML script that creates an automation to monitor the state changes of switch.basement_light and append the event and timestamp to a text file in the Home Assistant configuration directory.
yamlCopy code
automation:
  - id: log_basement_light_state_changes
    alias: Log Basement Light State Changes
      platform: state
      entity_id: switch.basement_light
      service: python_script.log_basement_light_state
Now, create a Python script in the config/python_scripts directory with the name log_basement_light_state.py (you may need to create the python_scripts directory if it doesn’t exist), and add the following content:
pythonCopy code
# log_basement_light_state.py
file_path = "/config/basement_light_log.txt"
event = "on" if data.get("new_state").state == "on" else "off"
timestamp = data.get("new_state").last_updated
with open(file_path, "a") as file:
    file.write(f"Event: {event}, Timestamp: {timestamp}\n")
This script checks whether the switch.basement_light is turning on or off, and then appends the corresponding event and timestamp to a text file (basement_light_log.txt) in the Home Assistant configuration directory.
Make sure to adjust the file_path variable if your configuration directory is located elsewhere.
And got the following error in my log:
Logger: homeassistant.components.python_script.log_basement_light_state.py
Source: components/python_script/__init__.py:224
Integration: Python Scripts (documentation, issues)
First occurred: 11:32:17 PM (2 occurrences)
Last logged: 11:32:18 PM
Error executing script: name 'open' is not defined
  File "/usr/src/homeassistant/homeassistant/components/python_script/__init__.py", line 224, in execute
    exec(compiled.code, restricted_globals)  # noqa: S102
  File "log_basement_light_state.py", line 8, in <module>
NameError: name 'open' is not defined
For some reason the built-in open is not being recognized. Check this guy that was having the same error: How to read a specific byte(s) from a binairy file - #18 by happybacon
