Cannot get rest to work
I installed the glances. I try to get the information of the time server running. I tried all sorts of things and I can not get the right information.
I open the link http://192.168.1.1.61208/api/3/uptime through the browser I get the result of time.
I will be happy to help how to get the information under the HA area developers under Template
  - platform: rest
    name: Glances - SERVER - Uptime
    value_template: '{{ value_json }}'
    resource: http://192.168.1.125:61208/api/3/uptime
Looking at the glances API reference for get uptime https://glances.readthedocs.io/en/latest/api.html#get-uptime it is reported like this {'seconds': 1178914} so you want:
  - platform: rest
    name: "Glances - SERVER - Uptime"
    value_template: "{{ value_json.seconds }}"
    unit_of_measurement: "s"
thank you for the answer
Still no result.
The template editor does not run the rest sensor platform to get the information, it only evaluates templates. So value_json in undefined in the editor. You have to paste the code into your config, restart then check the seonsor’s state in Developer Tools → States.
Good progress - it shows the uptime but it does not show the real uptime
“5 days, 13:50:15”
Go to http://192.168.1.125:61208/api/3/uptime in your web browser, take a screenshot and paste it here.
The template does work, if the result is according to the API document:
Ok, that is not what the API document says. Just do this:
  - platform: rest
    value_template: "{{ value }}"
Thank you very much - I helped me very much. Thanks.
I think if you want it just as a value in seconds you would have to do this:
  - platform: rest
    headers:
      Content-Type: application/json
If you are happy with how it reports in human readable format you can ignore this.
Thank you very much - I’ll check what the right for me.
Is it possible to remove the quotation marks?
Sure:
  - platform: rest
    value_template: "{{ value|replace('"','') }}"
Error loading /config/configuration.yaml: while scanning a quoted scalar in "/config/packages/unraid/unraid.yaml", line 5, column 41 found unexpected end of stream in "/config/packages/unraid/unraid.yaml", line 5, column 50
That does not look like it has anything to do with this.
He walks because of the code - I asked whether it was possible to lower the quotation marks.
And I showed you how.
Apparently you did not understand me-I copied your code, I put it and made a test through Ha. Then he shouted that the code was improper.
Are you putting this in a package?
Try it like this:
value_template: >
Make sure you copy the template exactly.
