I have two devices that are scene controllers – an Aeotec Minimote and (more importantly) a Cooper/Eaton RFWC5 5-button in-wall controller. The problem is I cannot get anything to show in the z-wave log when I press the scene buttons on either of these devices. I have read every single thread I can find (this is a big one) and I am stuck.
I have added the necessary COMMAND_CLASS_CENTRAL_SCENE as described in the Z-Wave device specific documentation for the RFWC5, and I have verified it stays there after multiple restarts. The RFWC5 is definitely part of the network – I can see it in the Z-Wave configuration settings page and I can successfully set some of its parameters (causing its indicator lights to stay on when I press one of its buttons, for example). But pressing the buttons creates absolutely zero visible events in the z-wave log.
I don’t know if it matters but my Z-wave controller is one of these Nortek USB sticks (apparently this is really the Sigma Designs UZB Z-Wave adapter). I note that in my zwcfg_*.xml file, under the controller node (id=1), it only has a single command class (COMMAND_CLASS_BASIC). Is that normal? Could that be part of the problem? I have nothing to compare it to.
I would really appreciate some help, as I have been dying to get an in-wall scene controller working for years… after seeing that z-wave scene activated events are now supported in HA, I figured I could get this to work and went ahead and bought one.
