Scheduler component and Scheduler Card installed correctly within HACS. However, when I install Scheduler Card on my Dashboard. I have an error message on top of the card stating: Could not connect with the scheduler component. It needs to be installed as integration before this card can be used. Scheduler component is installed at HACS, Integration and Scheduler Card is installed at HACS, Frontend.
$ cat log.txt
â—Ź [email protected] - Home Assistant
Loaded: loaded (/etc/systemd/system/[email protected]; enabled; vendor preset: enabled)
Active: active (running) since Mon 2023-03-27 09:39:08 PDT; 22h ago
Main PID: 123208 (hass)
Tasks: 16 (limit: 8755)
CPU: 13min 25.345s
CGroup: /system.slice/system-home\x2dassistant.slice/[email protected]
└─123208 /srv/homeassistant/bin/python3.11 /srv/homeassistant/bin/hass -c /home/homeassistant/.homeassistant
Mar 27 09:39:10 raspberrypi hass[123208]: 2023-03-27 09:39:10.700 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration scheduler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
Mar 27 09:39:10 raspberrypi hass[123208]: 2023-03-27 09:39:10.703 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
Mar 27 09:39:53 raspberrypi hass[123208]: 2023-03-27 09:39:53.484 ERROR (MainThread) [frontend.js.latest.202303091] http://raspberrypi:8123/lovelace/default_view:0:0 Uncaught
Mar 27 11:32:52 raspberrypi hass[123208]: 2023-03-27 11:32:52.454 ERROR (MainThread) [frontend.js.latest.202303091] http://raspberrypi:8123/lovelace/default_view:0:0 Uncaught
